i have a 1968 dodge coronet factory air car, i do not want to use all the out dated old stuff, i want to put all new, i have taken the p/s off the car and i have found a air compressor bracket that will fit where the p/s unit hooked up, is anybody running this set up? i have found all new stuff from here http://www.bouchillonperformance.com/BPE4705.asp
what is your take on this set, they sell all you need to hook the factory air up on the car.
