Traction issues #756916
07/24/10 06:37 PM
07/24/10 06:37 PM
Burlington, Ontario Canada
Dave_S Offline OP
Dave_S  Offline OP
My new found power is making my life miserable!
My sixty foot times are worse with the 512 than they were last year with my 440. The best I can do is 1.43 Cant seem to hook up. I've adjusted the caltracs and shocks from one extreme to the other. I even tried another set of tires just to rule them out. The car seems to hook then unload the tires. In the video you can see it bouncing a few times. Any suggestions?
3200 lbs 512 727 trans brake. Launch off two step @ 3400
Caltracs, mono-leafs, Ranchos in back , calvert 90/10's in front and 5.5 inches of front end travel
Video http://www.youtube.com/watch?v=VD5xWIbtcfI
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Traction issues [Re: Dave_S] #756917
07/24/10 07:47 PM
07/24/10 07:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Raise the launch rpm to hit the tire harder... go up
a fair amount
Re: Traction issues [Re: MR_P_BODY] #756918
07/24/10 07:50 PM
07/24/10 07:50 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
what shocks? and what are they set at? I'm in the same boat and can only launch at 3200. Then is spins after that. My Ranchos are set at #2 with one full turn of Pre load.
Re: Traction issues [Re: dc426] #756919
07/24/10 07:59 PM
07/24/10 07:59 PM
Dave_S Offline OP
Dave_S  Offline OP
I've tried with the shocks set from 0 up to 7 (ran out of time to go any higher)
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Traction issues [Re: Dave_S] #756920
07/24/10 08:02 PM
07/24/10 08:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Turn them all the way up
Re: Traction issues [Re: dc426] #756921
07/24/10 08:06 PM
07/24/10 08:06 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i have encountered that bouncing issue once. thats when i listened to someone slower than me.
how are your caltracs adjusted?
mine touch on the driver side without me in it and 6 flats of preload on the passenger side. think you need a stiffer shock setting too
Re: Traction issues [Re: MR_P_BODY] #756922
07/24/10 08:19 PM
07/24/10 08:19 PM
UK
602heavy Offline
602heavy  Offline
UK
Having the same issues with same set up as your's , blowing the tyres away on launch , next time out i'm gonna change front shock to 70/30 , maybe the front end is coming up to fast & not allowing the rear end to work hard enough , bit like the guy on the scales holding a 20ft scaffold board with his mate supporting the other end , when he tries to lift the board on his own the scales read his weight plus the board , when his mate helps him lift the board the weight on scales does'nt alter much........i read this somewhere before so it stuck in my mind , the guy was talking about higher hp motors sometimes need a slower rebounding shock on fronts.
Re: Traction issues [Re: Dave_S] #756923
07/24/10 08:50 PM
07/24/10 08:50 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
I have the same problem with my car. everybody in this forum talk so well about Cal tracks, but in a marginal track I don´t think it works the way everyone´s saying it does. I personally went back to my SS springs, they work better for me
Re: Traction issues [Re: cbarracuda] #756924
07/24/10 09:09 PM
07/24/10 09:09 PM
Tampa Florida
dc426 Offline
dc426  Offline
Tampa Florida
General consensus and Calvert advises to go down on shock settings when using a T-brake. Foot braking I have to be on 9, T-brake 2. Seems to work for me.
BTW, tire pressure is critical. What size tires and what pressure are you running?
Re: Traction issues [Re: dc426] #756925
07/24/10 09:23 PM
07/24/10 09:23 PM
MI
68shifter Offline
68shifter  Offline
MI
I had a similar issue as well. They called it porpoising (sp?). I dealt a good deal with Scott and John at Calvert. They were adamant about leaving the front loose for transfer and unlimited and stiff shocks on the rear. Also they also stuck firm to half turn preload with driver. At one point I was trying three different sets of rear shocks and was/am using double adj on the front. Once I got the car consistent any change in track or weather and back to square one. I got rid of the mono=leafs and went back to SS springs.
Not saying it can't be done - but call Calvert get them some video and just be ready to really work it out.
Just my experience Good luck
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Traction issues [Re: dc426] #756926
07/24/10 11:50 PM
07/24/10 11:50 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
15x10.5x33 10 pounds seem to work best for me because of the poor traction
Re: Traction issues [Re: cbarracuda] #756927
07/25/10 12:21 AM
07/25/10 12:21 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
If you have the money buy a set of afco double adjustable shocks for the rear. I run them and qa1's up front with cal-tracs. I also have my dart lowered in the back 2 inches to aid in weight transfere.
Re: Traction issues [Re: Dave_S] #756928
07/25/10 05:17 AM
07/25/10 05:17 AM
USA
540DUSTER Offline
540DUSTER  Offline
USA
Whats the angle of the rear shackels?
Re: Traction issues [Re: Dave_S] #756929
07/25/10 06:40 AM
07/25/10 06:40 AM
Q
Quicktree Offline
Quicktree  Offline
Q
time to upgrade the shocks and check the front end.
Re: Traction issues [Re: Quicktree] #756930
07/25/10 07:28 AM
07/25/10 07:28 AM
sweden
sshemi Offline
sshemi  Offline
sweden
You should have adjustable front shocks also.
90/10 works good for lower hp cars but when the hit gets violent you need to slow the front end down a little bit. dubble adjustable for the rear is almost a must when useing a t-break.
Im not saying everybody will need them but my experience says its a good investment.
If it first hooks then spinn i would use tyhe hardest setting on the rear shocks and if that doesnt work get yourself adj front shocks to slw the front down and if that doesnt work time for dub adj rears.
Re: Traction issues [Re: sshemi] #756931
07/25/10 07:33 AM
07/25/10 07:33 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: Traction issues [Re: Quicktree] #756932
07/25/10 10:02 AM
07/25/10 10:02 AM
Dave_S Offline OP
Dave_S  Offline OP
thanks for the tip guys.
The tires are M/T 29.5x10.5 x15. I've tried tire pressures from 12 to 14 psi.
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Traction issues [Re: Dave_S] #756933
07/25/10 10:29 AM
07/25/10 10:29 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You may want to give it a try with shocks at 9 and at least 2 full turns of negative pre load. When I went from a 452 to my 542 RIP I had to do that after trying everything. I put an air shock over the pass wheel with 65 lb in it and just kept backing the bars off till it launched nice and smooth. Went from 1 1/4 turn pre load to 2 1/4 negative and walla that was the ticket. Course that was foot braking and it went 1.400 short in my 3620 GTX
then after the 542 went to Big block heaven went back to a 452 and back to about 1 1/4 turns pre load still using the air shock keeps it even leaving and can set bars the same no need for extra flats pass rear.
now I went from a 4000 stall to a 5000 stall and it's a bit different again kinda chasing it a bit still? Yours almost looks like it hits and kicks back instead of lifting front good and that is what my 542 did only even more dramatic.
You may have to set it so you can get in the top hole if your not on an A body.
( I have one air shock left?? LOL!!)
Re: Traction issues [Re: Dodgem] #756934
07/25/10 10:52 AM
07/25/10 10:52 AM
Q
Quicktree Offline
Quicktree  Offline
Q
air shock
Re: Traction issues [Re: Quicktree] #756935
07/25/10 11:13 AM
07/25/10 11:13 AM
Tampa Florida
dc426 Offline
dc426  Offline
Tampa Florida
I'm starting to think you have too much air in the tires. I run Hoosier 10.5X30. Foot braking I run 14.5 pounds. T-braking I run anywhere from 10-11 depending on the track. Foot braking I run a 1/4 turn of PL and T-braking one full turn.
Here's a vid of my last outing. 3200 RPM, 10.5 pounds in the tires with 1 full turn of pre load. Ranchos set at 2.
http://www.youtube.com/watch?v=-ejlLfrdf8I
