My new found power is making my life miserable!
My sixty foot times are worse with the 512 than they were last year with my 440. The best I can do is 1.43 Cant seem to hook up. I've adjusted the caltracs and shocks from one extreme to the other. I even tried another set of tires just to rule them out. The car seems to hook then unload the tires. In the video you can see it bouncing a few times. Any suggestions?
3200 lbs 512 727 trans brake. Launch off two step @ 3400
Caltracs, mono-leafs, Ranchos in back , calvert 90/10's in front and 5.5 inches of front end travel
Video
http://www.youtube.com/watch?v=VD5xWIbtcfI
