does 95 truck have reverse thread fan clutch? #756880
07/24/10 05:21 PM
07/24/10 05:21 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
1995 dodge 1500 with a 5.9 engine. I can't get the fan clutch nut off. Does anyone know if this vehicle used reverse threads??
Re: does 95 truck have reverse thread fan clutch? [Re: frank] #756881
07/24/10 05:35 PM
07/24/10 05:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Hammer and long punch. Put the punch on the edge of a flat on the the nut and hit it toward the pssenger side. One hard quick hit aught to do it.
Re: does 95 truck have reverse thread fan clutch? [Re: stumpy] #756882
07/24/10 06:57 PM
07/24/10 06:57 PM
IN
ahy Offline
ahy  Offline
IN
I understand all gas engines are standard thread. Some Cummins may be left hand.
I just did an '06 Durango. It was a bear. My usual method - hit the wrench with a hammer didn't work. I tried the punch method except with an air impact hammer. Didn't work. I finally made a pulley holding tool - steel strip from the arm of a retired garage door opener with 2 studs to engage the holes in the pulley. With a long handle on the holding tool and a cheater on the wrench I got it.
Re: does 95 truck have reverse thread fan clutch? [Re: frank] #756883
07/24/10 07:00 PM
07/24/10 07:00 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
All the Gas engines are right hand thread,...only the diesels are left hand thread,....generally a 36 MM fan wrench makes life easy, avaliable at most Autozone stores "free" to use with a deposit returned, when brought back
I've seen some "factory" assys with red loctite on the nuts threads, just use a simple hand held propane torch to heat up the loctite, to break the chemical bond, small amount of heat
Mike
Re: does 95 truck have reverse thread fan clutch? [Re: DAYCLONA] #756884
07/24/10 08:13 PM
07/24/10 08:13 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
They are right as said.Ive removed hundreds.I use my air chisel with a long chisel.Just bump it on the flats and when they come loose they spin off.When I install them just spin it on and a bump with the chisel tightens them.You need a chises on the air hammer.Just get a flat where it easy to get to and move the fan blade till you can get to it.This should be put in the archives as its asked probally 5 times a week.All left hand threads have a sticker or its embossed on the shroud.Rocky
Chrysler Firepower
Re: does 95 truck have reverse thread fan clutch? [Re: therocks] #756885
07/24/10 08:52 PM
07/24/10 08:52 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Just did my 01 Ram.. what a nightmare..
I own a wrench nig enough, but it would not come loose, I finally resorted to the air chisel method and it came loose..
BUT,
when I went to install the new one, it screwed on easily about 5 turns and locked up...
Dont know if the pump shaft was nicked from the air chisel or the threads in the new clutch were bad...
Anyway,
I had to borrow the proper wrenchs from a dealer mechanic to finish tighting it up..
One has two pins to go into the water pump pulley, the other wrench the nut wrench..
