Just did my 01 Ram.. what a nightmare..
I own a wrench nig enough, but it would not come loose, I finally resorted to the air chisel method and it came loose..
BUT,
when I went to install the new one, it screwed on easily about 5 turns and locked up...
Dont know if the pump shaft was nicked from the air chisel or the threads in the new clutch were bad...
Anyway,
I had to borrow the proper wrenchs from a dealer mechanic to finish tighting it up..
One has two pins to go into the water pump pulley, the other wrench the nut wrench..
