Big block in a 65 Fury #75567
06/18/08 05:58 PM
06/18/08 05:58 PM
Central Ohio
Ledman_70 Offline OP
Central Ohio
Hey guys, I have a chance to buy a 65 Fury 1 sedan that was a /6 car, but I'd like to put a 413 in it. I didn't know the 65 C bodies don't have a removable K-frame and the /6 mounts are no where near the 413 mounts. Has anyone done this swap? What does it take? It looks to me like either cutting and welding a new K-frame or using elephant ears. Can someone enlighten me? I'd like to make a C body A990 clone. Thanks
Jeff Adams 64 426 Polara
Re: Big block in a 65 Fury [Re: Ledman_70] #75568
06/18/08 06:11 PM
06/18/08 06:11 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Crawl up under the car. It's removable, it's just a much bigger piece. That said I think I'd mount the engine/trans starting with the trans mount and get the engine in the correct location and fabricate something.
Re: Big block in a 65 Fury [Re: Ledman_70] #75569
06/18/08 06:15 PM
06/18/08 06:15 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
`65 C body big block mounts and subframe are a one year only oddball and you really don`t want to get into that. Best plan is to swap in a `66 or later subframe (it`s a bolt in but more involved than a K frame swap) You will need a `66 steering column too because the `65 is cable shifted.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Big block in a 65 Fury [Re: gamagoat6x6] #75570
06/18/08 06:53 PM
06/18/08 06:53 PM
Andrewh Offline
Andrewh  Offline
how to remove the sub frame from a 68
http://www.turbinecar.com/68-fury/rmvfrm.htm
I took one out once, never put one back in, so don't know how the line up stuff goes.
Re: Big block in a 65 Fury [Re: Ledman_70] #75571
06/19/08 11:55 AM
06/19/08 11:55 AM
Central Ohio
Central Ohio
I didn't crawl under the car, but I didn't see where the K-frame was removable... where does it unbolt? The car was originally a /6 3-spd, but I would put a 413/727 in it, so the steering column would be an issue as it already has a floor shift column in it. How hard is it to swap the cradle and how hard are they to find?
Re: Big block in a 65 Fury [Re: Ledman_70] #75572
06/19/08 12:03 PM
06/19/08 12:03 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The entire front frame section bolts in. I have dismantled a 69 Polara, but never put one back together.
