Re: 440 Oil Leaks
[Re: 340SHORTY]
#755690
07/23/10 08:54 AM
07/23/10 08:54 AM
Posts: 3,385 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Distributor hold down is a blind hole. Shouldn't be anything coming out of there.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
Re: 440 Oil Leaks
[Re: wingman]
#755691
07/23/10 02:24 PM
07/23/10 02:24 PM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
Re: 440 Oil Leaks
[Re: KryslerKid]
#755694
07/23/10 04:14 PM
07/23/10 04:14 PM
Posts: 366 San Gabriel, CA 91775
rexus31
Pull the valve cover. Place a small light on a flat surface (workbench) and with the gasket on place the valve cover over it. Press down on the two center bolt hole locations. If there is light shinning through your cover is tweaked and you will have to get out a piece of wood and a hammer and adjust it until it lays flat and you see no light shining through. If the light can pass the oil can as well.
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue
1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
