drive shaft loop ??? #754689
07/21/10 08:23 PM
07/21/10 08:23 PM
Finally a HUSKER again
Moparnut426 Offline OP
Well I have never needed a loop, and just dont know if its installed correctly. It doesnt hit with the rearend all the way hanging down. and I have plenty of room with the rearend on the ground.
Any sugjestions
Kasey
Re: drive shaft loop ??? [Re: Moparnut426] #754690
07/21/10 08:26 PM
07/21/10 08:26 PM
Casa Grande,Arizona
DennisJ Offline
super street
DennisJ  Offline
super street
Casa Grande,Arizona
The loop has to be within 6 inches of the front u-joint.
Dennis Jokela
I started out with nothing,and I still have most of it.
Re: drive shaft loop ??? [Re: Moparnut426] #754691
07/21/10 08:26 PM
07/21/10 08:26 PM
Also there is a hole on the top, Mancini A body loop, is that there for suport to the floor pan?
O can make a spacer, and use a carriage bolt and bolt it down back there.
Oh and I really need to store this car in a dryer environment, the humidity killed the paint on the tranny.
Kasey
Re: drive shaft loop ??? [Re: DennisJ] #754692
07/21/10 08:37 PM
07/21/10 08:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dennis Jokela
Yep... within 6" of the joint
Re: drive shaft loop ??? [Re: MR_P_BODY] #754693
07/21/10 08:43 PM
07/21/10 08:43 PM
Well, it looks like I have to move it huh...
Kasey
Re: drive shaft loop ??? [Re: Moparnut426] #754694
07/21/10 08:49 PM
07/21/10 08:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Kasey
And that rear hole on the top... I would use it to bolt
it to the floor(with spacers if needed to center it...
I dont like the back out there floating in space
if the shaft come off)
Re: drive shaft loop ??? [Re: MR_P_BODY] #754695
07/21/10 08:53 PM
07/21/10 08:53 PM
Yep, If I would have know how simple this thing is, I would have built one my self.
I am going to bolt the back to the floor. I also dont like it flopping around back there.
Kasey.
Oh and whats with the 6"
Re: drive shaft loop ??? [Re: Moparnut426] #754696
07/21/10 09:00 PM
07/21/10 09:00 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Per NHRA ......... must be located within 6 " of front U joint.
I used the old school 26.00 safety loop.......bolted through the floor and with a little heat and beat , it is a very snug fit.
Now that I am switching to a 904 , I may have to move mine , but then , I could also shove the motor back a bit since I am switching to motor plates too.
Re: drive shaft loop ??? [Re: tubtar] #754697
07/21/10 09:41 PM
07/21/10 09:41 PM
Well, Ill get the thing bolted in there in the AM,
Kasey
Re: drive shaft loop ??? [Re: Moparnut426] #754698
07/22/10 10:03 PM
07/22/10 10:03 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
At least you put one in there. That is something that would cause a lot of newbies trouble at the tech stand. Back when we had tech stands. Now days at a lot of tracks, if you have the $ for the entry fee, you pass tech.
Glad to see you care enough to do it right.
Brian Dunnigan
Re: drive shaft loop ??? [Re: '72CudaRacer] #754699
07/22/10 10:40 PM
07/22/10 10:40 PM
408Dust Offline
408Dust  Offline
Not trying to be a wise guy but do your self a favor and buy or borrow a rule book.
Re: drive shaft loop ??? [Re: 408Dust] #754700
07/23/10 04:13 AM
07/23/10 04:13 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Anyone used a Lakewood "universal" loop in an A body - is there much fabbing to do?
