pressure specs for valve spring #75462
06/18/08 01:43 PM
06/18/08 01:43 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
MP 3690933
thanks
Re: pressure specs for valve spring [Re: NachoRT74] #75463
06/18/08 02:18 PM
06/18/08 02:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Don't have the spec's but the Mopar part number is: P3690933.
Not MP 3690933 which may be a jobber used number.
Re: pressure specs for valve spring [Re: NachoRT74] #75464
06/18/08 02:23 PM
06/18/08 02:23 PM
N
NITROUSN Offline
NITROUSN  Offline
N
P3690933 1.83"/1.86" Single/Damper 1.53" 0.224" 0.440"/0.500" Chrome
Vandium
From the mp catalog. The mp engine secrets should have the pressures.
Re: pressure specs for valve spring [Re: NITROUSN] #75465
06/18/08 04:21 PM
06/18/08 04:21 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
I think that spring is 110lbs at 1.860 but I
will have to check. Good for hydraulic street
cam.
logan426
Re: pressure specs for valve spring [Re: NachoRT74] #75466
06/18/08 04:33 PM
06/18/08 04:33 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
115lbs at 2" checking height
310lbs at 1.50"
Install at 1.83" to 1.86"
Rich H.
Esse Quam Videri
Re: pressure specs for valve spring [Re: ZIPPY] #75467
06/22/08 11:06 AM
06/22/08 11:06 AM
Valencia, España
Valencia, España
ok, and what about the production Mopar PN 2658904 Valve spring ?
Re: pressure specs for valve spring [Re: NachoRT74] #75468
06/23/08 04:57 PM
06/23/08 04:57 PM
Valencia, España
Valencia, España
Re: pressure specs for valve spring [Re: NachoRT74] #75469
06/24/08 04:08 PM
06/24/08 04:08 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That part number does not exist in Chrysler's computer system. Maybe it did at one time, long ago, but not now.
Re: pressure specs for valve spring [Re: ZIPPY] #75470
06/24/08 04:09 PM
06/24/08 04:09 PM
Valencia, España
Valencia, España
is supposelly stock spring for BB/RB HPs blocks... will post the 70/71 mopar catalog page
Re: pressure specs for valve spring [Re: NachoRT74] #75471
06/24/08 04:14 PM
06/24/08 04:14 PM
Valencia, España
Valencia, España
sorry... is not 904 is 204
went toi check onm the springs I have and definitelly misstype the number
2658204
Re: pressure specs for valve spring [Re: NachoRT74] #75472
06/24/08 04:21 PM
06/24/08 04:21 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That's a dead part number as of 1983, sorry
Re: pressure specs for valve spring [Re: ZIPPY] #75473
06/29/08 02:38 AM
06/29/08 02:38 AM
Valencia, España
Valencia, España
ok, but they should have specs the same, no matter if dead part number
