65 Slip Yoke Transmission #75444
06/18/08 12:33 PM
06/18/08 12:33 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
So whats the big deal with these trannys? Ive heard they are very desireable...What makes them desireable?
Re: 65 Slip Yoke Transmission [Re: SPWC] #75445
06/18/08 12:36 PM
06/18/08 12:36 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I believe they're desirable to the push-button shifter guys, because they're still cable operated but have the slip yoke on the rear instead of the older ball and trunion setup.
Re: 65 Slip Yoke Transmission [Re: 440newport] #75446
06/18/08 01:03 PM
06/18/08 01:03 PM
Why, do you want one?
Re: 65 Slip Yoke Transmission #75447
06/18/08 01:18 PM
06/18/08 01:18 PM
6T4 Polara Offline
6T4 Polara  Offline
With Imperials conversion kit for adapting the newer 727 to the older push button style shifters not that big of demand for the 65.
John
Re: 65 Slip Yoke Transmission [Re: 6T4 Polara] #75448
06/18/08 01:57 PM
06/18/08 01:57 PM
Marion,Indiana
Seth_Jones Offline
Seth_Jones  Offline
Marion,Indiana
Isn't Imperials kit like $365 though?I'll stick with the 65 trans I think.
Re: 65 Slip Yoke Transmission [Re: Seth_Jones] #75449
06/18/08 02:39 PM
06/18/08 02:39 PM
Chesapeake Va
BobK Offline
BobK  Offline
Chesapeake Va
I talked to the guys at Imperial Services & it is quite a bit more than that for everything. Also, there is a waiting time for getting your shifter buttons back.
1964 Plymouth Fury x 2
1964 Plymouth Sport Fury
Re: 65 Slip Yoke Transmission [Re: BobK] #75450
06/18/08 05:01 PM
06/18/08 05:01 PM
SPWC Offline OP
SPWC  Offline OP
Not at this time. I was just wondering because awhile ago I purchased a Mopar Tailshaft at a swapmeet for $2. Posted a WIW here and someone PM'd me some info about the part being desireable.
Ended up selling the item on the "Bag" for $152.After putting a reserve of $50 on it.
I was shocked,and always wondered what the big deal was with the slip yoke stuff.
Re: 65 Slip Yoke Transmission [Re: SPWC] #75451
06/19/08 07:36 AM
06/19/08 07:36 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
A 65 slip-yoke trans is a 1-year-only trans. Desirable? Depends on who needs it. And for console-shift pre-66 cars there is a simple work-around that allows a 66-up trans to be used.
I sold a 65 trans at a swap meet last year, expecting to have a goldmine on my hands, but only one guy asked about it. He ended up beating me down to $250 (not incredibly much more than a regular 727).
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
