Bake Booster Vacuum Leak #754392
07/21/10 02:08 PM
07/21/10 02:08 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
I have been suspecting my brake booster on the 68 charger has been leaking and causing a miss for a while, i just recently disconnected it all together and it turned out to be the case. Now that i know its a leak how can i go about fixing it? Some on told me it should be the check valve but should i look else where on the unit? Thank you.
Re: Bake Booster Vacuum Leak [Re: 440_ci] #754393
07/21/10 02:12 PM
07/21/10 02:12 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
The check valve is the only thing you can service so if it's not that then you need to replace the booster.
Re: Bake Booster Vacuum Leak [Re: stumpy] #754394
07/21/10 02:18 PM
07/21/10 02:18 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
Hmm okay i kinda figured as much, thanks for the quick reply.
