Brake problems..... #754151
07/21/10 01:43 AM
07/21/10 01:43 AM
DELAWARE
bee71mopar Offline OP
DELAWARE
Going to get the 69 Plymouth Fury inspected this afternoon I had power drum brakes..had to slam on brakes but not extremely hard...still had brakes get to DMV power booster not working (not good) At least I think that is what's wrong....pull out of DMV and no booster driving in traffic for 15 to 20 miles home..what's wrong with this thing could it just be air in the lines from sitting..checked the vacuum when I got home and has plenty...
Re: Brake problems..... [Re: bee71mopar] #754152
07/21/10 09:50 AM
07/21/10 09:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
What are the brakes doing?Is the pedal rock hard or is there no pedal?You dont say whats wrong.Rocky
Chrysler Firepower
Re: Brake problems..... [Re: bee71mopar] #754153
07/22/10 01:27 PM
07/22/10 01:27 PM
DELAWARE
DELAWARE
They are rock hard but will stop with a lot of effort
Re: Brake problems..... [Re: bee71mopar] #754154
07/22/10 01:35 PM
07/22/10 01:35 PM
I'd be inclined to think booster but if it has sat for along time it could be a lining prob. Might split the M/C from the booster & pull it forward several inches & start it & hit the brakes & report how it feels
Re: Brake problems..... [Re: RapidRobert] #754155
07/22/10 01:57 PM
07/22/10 01:57 PM
Andrewh Offline
Andrewh  Offline
check in the engine compartment first.
see if there is a split in the vacuum line and you hear hissing anywhere.
then unplug the line and see if it changes anything.
engine running rougher or whatever?
check if you can pull a vacuum on the booster.
Re: Brake problems..... [Re: bee71mopar] #754156
07/22/10 02:43 PM
07/22/10 02:43 PM
DELAWARE
DELAWARE
checked and replaced the hose..There was no hissing though..no change..bled the brakes yesterday lot of air in the back rear but no change..clean fluid was surprised...pulled the hose off of the booster while engine running no change..still hard pedal..Taken the left side wheels off today to replace the (left hand threaded studs)
Re: Brake problems..... [Re: bee71mopar] #754157
07/22/10 02:51 PM
07/22/10 02:51 PM
Andrewh Offline
Andrewh  Offline
with a vacuum leak that size, the engine should have ran worse.
make sure you are getting vacuum through that line, then do a vacuum test on teh booster.
Re: Brake problems..... [Re: bee71mopar] #754158
07/22/10 04:22 PM
07/22/10 04:22 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Air makes a mushy pedal.Bad booster makes hard pedal.Check the valve in the booster.Just pull it off.If vacuum releases with engine off the booster is bad or the rods are not correct.The valves can get plugged also.Rocky
Chrysler Firepower
Re: Brake problems..... [Re: bee71mopar] #754159
07/24/10 03:17 PM
07/24/10 03:17 PM
DELAWARE
DELAWARE
Well back at it again..I split the M/C and booster pedal still hard..checked the check valve and swapped it out with another still no change..I am beginning to think it is the booster..took it out for a ride and hard brakeing the whole time and front end shook like crazy while braking..No fun driving with all drum brakes..any help needed..I just got this thing inspected and all new interior..I cant stop now ..
Re: Brake problems..... [Re: bee71mopar] #754160
07/24/10 03:20 PM
07/24/10 03:20 PM
DELAWARE
DELAWARE
oh yea one other thing I put my head under the dash while the car was running shut it off and heard some hissing while pushing on the brake...(bad booster)...I even replaced the foam gasket between the M/c and booster
Re: Brake problems..... [Re: RapidRobert] #754161
07/24/10 03:22 PM
07/24/10 03:22 PM
DELAWARE
DELAWARE
I guess your talking about the booster lining? RapidRobert
Re: Brake problems..... [Re: bee71mopar] #754162
07/24/10 03:45 PM
07/24/10 03:45 PM
Actually I was thinking of linings as in shoes & trying to (early on) pin it down to whether it was a booster/mc prob up top or down below the shoes not grabbing from glazing/contamination or stuck wheel cyl(s) but if you seperated the M/C out from the booster and (eng running) hit the pedal and it's not going down & is hard then it's a booster prob and I'm not up on them enough (always ran manual) to know if the check valve could be the culprit (& if it's easily replaced) and not have to get another booster but I'd say the booster is bad & that's what needs to be swapped out
Re: Brake problems..... [Re: RapidRobert] #754163
07/24/10 03:55 PM
07/24/10 03:55 PM
DELAWARE
DELAWARE
Thanks for your help.. its just kinda odd that it went out on me so quick I had put on brakes kinda hard and then drove about 5 miles down the road and no power brakes..When I pulled the m/c and booster apart I vacuumed out the booster because it had a lot of dirt in it hoping that would do it but not..
Re: Brake problems..... [Re: bee71mopar] #754164
07/24/10 03:59 PM
07/24/10 03:59 PM
Good luck & holler on how it turns out as I need more PB edumacation in case I ever convert to PB
Re: Brake problems..... [Re: bee71mopar] #754165
07/24/10 04:15 PM
07/24/10 04:15 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Shade tree test of power brakes:
1. With engine off, pump brakes 5-10 times to expend any stored vacuum in the booster.
2. Place foot on brake pedal with very slight, constant pressure.
3. Start the engine.
A power booster that is working will have the brake pedal drop under your slight, constant foot pressure once there's vacuum. A dead booster will leave the pedal where it is.
Note that a dead booster and one not getting any vacuum due to other failures (cracked/plugged vacuum hose, bad check valve) will manifest the same. You need to eliminate the vacuum supply issues before condemning the booster.
Down to just a blue car now.
