Re: Brake problems.....
[Re: bee71mopar]
#754152
07/21/10 09:50 AM
07/21/10 09:50 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
What are the brakes doing?Is the pedal rock hard or is there no pedal?You dont say whats wrong.Rocky
Chrysler Firepower
[Re: bee71mopar]
#754154
07/22/10 01:35 PM
07/22/10 01:35 PM
RapidRobert
I'd be inclined to think booster but if it has sat for along time it could be a lining prob. Might split the M/C from the booster & pull it forward several inches & start it & hit the brakes & report how it feels
[Re: bee71mopar]
#754158
07/22/10 04:22 PM
07/22/10 04:22 PM
therocks
Niles , Ohio
Air makes a mushy pedal.Bad booster makes hard pedal.Check the valve in the booster.Just pull it off.If vacuum releases with engine off the booster is bad or the rods are not correct.The valves can get plugged also.Rocky
Chrysler Firepower
[Re: bee71mopar]
#754164
07/24/10 03:59 PM
07/24/10 03:59 PM
RapidRobert
Good luck & holler on how it turns out as I need more PB edumacation in case I ever convert to PB
[Re: bee71mopar]
#754165
07/24/10 04:15 PM
07/24/10 04:15 PM
Posts: 9,312 SoCal
68HemiB
SoCal
Shade tree test of power brakes:
1. With engine off, pump brakes 5-10 times to expend any stored vacuum in the booster.
2. Place foot on brake pedal with very slight, constant pressure.
3. Start the engine.
A power booster that is working will have the brake pedal drop under your slight, constant foot pressure once there's vacuum. A dead booster will leave the pedal where it is.
Note that a dead booster and one not getting any vacuum due to other failures (cracked/plugged vacuum hose, bad check valve) will manifest the same. You need to eliminate the vacuum supply issues before condemning the booster.
Down to just a blue car now.
