Small block to big block? #753909
07/20/10 10:51 PM
07/20/10 10:51 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Taking the 318/904 out of a early B body (1964), and replacing it with a later year 383/727 or 440/727. How difficult? Mostly changing mounts? K-member? Shaft length? Other problems? Thanks!
Re: Small block to big block? [Re: polkat] #753910
07/21/10 01:52 AM
07/21/10 01:52 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
the deal is not on relation between motor is on mounts and K member with your year... so as far you get right motor mounts to your car and to the engine family, everything should it be fit right.
diff with K member began on 73 and lates B bodies
then also on A bodies at same year or so, BUT just between the mounts kind ( spool or block ), not really engine family, since no A bodies with BB/RB were offered.
Re: Small block to big block? [Re: polkat] #753911
07/21/10 06:29 AM
07/21/10 06:29 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Drive shaft willl be teh same. There is no difference in tail shaft legth between big and small block car 727's.
Re: Small block to big block? [Re: MoparforLife] #753912
07/21/10 06:33 AM
07/21/10 06:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
ppppssssttt , he is taking out a 904
Re: Small block to big block? [Re: JohnRR] #753913
07/21/10 08:37 AM
07/21/10 08:37 AM
Upper Midwest
Upper Midwest
ppppssssttt- sorry I missed that - only about 4 inches difference and a yoke change.
Re: Small block to big block? [Re: MoparforLife] #753914
07/21/10 09:30 AM
07/21/10 09:30 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Yea, as I understand it (haven't looked yet) rather then a U joint behind the tranny, there is some kind of trunnen (SP) joint?
