Re: Small block to big block?
[Re: polkat]
#753910
07/21/10 01:52 AM
07/21/10 01:52 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
the deal is not on relation between motor is on mounts and K member with your year... so as far you get right motor mounts to your car and to the engine family, everything should it be fit right.
diff with K member began on 73 and lates B bodies
then also on A bodies at same year or so, BUT just between the mounts kind ( spool or block ), not really engine family, since no A bodies with BB/RB were offered.
[Re: polkat]
#753911
07/21/10 06:29 AM
07/21/10 06:29 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Taking the 318/904 out of a early B body (1964), and replacing it with a later year 383/727 or 440/727. How difficult? Mostly changing mounts? K-member? Shaft length? Other problems? Thanks!
Drive shaft willl be teh same. There is no difference in tail shaft legth between big and small block car 727's.
[Re: MoparforLife]
#753912
07/21/10 06:33 AM
07/21/10 06:33 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
ppppssssttt , he is taking out a 904
[Re: JohnRR]
#753913
07/21/10 08:37 AM
07/21/10 08:37 AM
MoparforLife
Upper Midwest
ppppssssttt- sorry I missed that - only about 4 inches difference and a yoke change.
