Re: PICS OF SHACKLES WITH SS SPRINGS.
[Re: MIKES_DUSTER]
#753869
07/21/10 10:18 AM
07/21/10 10:18 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Mine are angled in the wrong direction...Why would this happen???
Mike, i've had the shackles do this on 2 SS spring installations, it would lift the car so much that the shackles were angled around 1:00 (top) & 7:00 possition, you will need to currect this by adding blocks behind the shackle mounts to get it to at least around 11:00 & 5:00.
Now are you shure you are looking at it right?
[Re: MIKES_DUSTER]
#753871
07/21/10 10:27 AM
07/21/10 10:27 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Either you moved the whole axle and front spring boxes forward OR the front segments of the springs are shorter... you want 30*-35* on the shackle (top leaning forward)
[Re: MR_P_BODY]
#753873
07/21/10 10:30 AM
07/21/10 10:30 AM
Posts: 438 Great Lakes Region
abodiesonly1
Great Lakes Region
I agree. Are the springs in the factory location or moved into the frame?
[Re: abodiesonly1]
#753874
07/21/10 10:38 AM
07/21/10 10:38 AM
MR_P_BODY
Also a very stiff spring will lift the body way too much to give the same effect.... the engine not being in the car will have little to no change on the back end unless you have moved the engine rearward... the rear segment is the spring portion of the spring the front segment is the locator and lift portion
[Re: quick77rt ]
#753877
07/21/10 04:35 PM
07/21/10 04:35 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
You might consider the afco rear spring sliders if you have to find a fix.
I went this way. It also dropped the car about an inch in the tail , which was cool with me. They pop up on ebay once in a while........I got them for 80.00 new.
[Re: MIKES_DUSTER]
#753879
07/21/10 06:08 PM
07/21/10 06:08 PM
joedust451
super gas
super gas
Branson, Mo.
Does anyone know what would cause it?? They are 002/003 springs.
More arch on the springs.
[Re: MIKES_DUSTER]
#753881
07/21/10 06:48 PM
07/21/10 06:48 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
So am I gonna have to put 2"-3" blocks in to fix the problem??
i would think you would be better off moving the shackle mount on the frame.
[Re: MIKES_DUSTER]
#753882
07/21/10 07:42 PM
07/21/10 07:42 PM
tubtar
St. Paul , Mn.
If it is anything like mine........1 " might be plenty. ( 1965 Dart ) I made boxes in the 3 " neighborhood and it was too much by a bunch. That was with the 7/8ths offset kit. I went to sliders when I moved the springs under the frame rails.
