Page 1 of 3 1 2 3
PICS OF SHACKLES WITH SS SPRINGS. #753866
07/20/10 10:50 PM
07/20/10 10:50 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
I dont think mine are angled right.
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: MIKES_DUSTER] #753867
07/21/10 07:47 AM
07/21/10 07:47 AM
Mountains of NM
65superstock Offline
Mountains of NM
I used this when I did mine:
http://www.moparts.org/Tech/Archive/rearsusp/5.html
-Jason
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: 65superstock] #753868
07/21/10 10:08 AM
07/21/10 10:08 AM
Mine are angled in the wrong direction...Why would this happen???
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: MIKES_DUSTER] #753869
07/21/10 10:18 AM
07/21/10 10:18 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Mike, i've had the shackles do this on 2 SS spring installations, it would lift the car so much that the shackles were angled around 1:00 (top) & 7:00 possition, you will need to currect this by adding blocks behind the shackle mounts to get it to at least around 11:00 & 5:00.
Now are you shure you are looking at it right?
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: joedust451] #753870
07/21/10 10:21 AM
07/21/10 10:21 AM
Yes,looking at it right....Now,my motor is not in the car yet,will that make a difference??? Top of shackle is at 1:00 and the bottom is at 7:00 just like yours was.
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: MIKES_DUSTER] #753871
07/21/10 10:27 AM
07/21/10 10:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Either you moved the whole axle and front spring
boxes forward OR the front segments of the springs
are shorter... you want 30*-35* on the shackle (top
leaning forward)
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: MIKES_DUSTER] #753872
07/21/10 10:27 AM
07/21/10 10:27 AM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
If it is 1 and 7 on the right side your good if left time for some blocks
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: MR_P_BODY] #753873
07/21/10 10:30 AM
07/21/10 10:30 AM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
leaning forward)
I agree. Are the springs in the factory location or moved into the frame?
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: abodiesonly1] #753874
07/21/10 10:38 AM
07/21/10 10:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
leaning forward)
Also a very stiff spring will lift the body way too
much to give the same effect.... the engine not being
in the car will have little to no change on the back
end unless you have moved the engine rearward...
the rear segment is the spring portion of the spring
the front segment is the locator and lift portion
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: abodiesonly1] #753875
07/21/10 10:42 AM
07/21/10 10:42 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
You might consider the afco rear spring sliders if you have to find a fix.
Maybe some small mounting boxes needed to give the spring istall its proper oem position would be needed.
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: abodiesonly1] #753876
07/21/10 10:47 AM
07/21/10 10:47 AM
Stock location.
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: quick77rt ] #753877
07/21/10 04:35 PM
07/21/10 04:35 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I went this way.
It also dropped the car about an inch in the tail , which was cool with me.
They pop up on ebay once in a while........I got them for 80.00 new.
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: tubtar] #753878
07/21/10 05:59 PM
07/21/10 05:59 PM
Does anyone know what would cause it?? They are 002/003 springs.
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: MIKES_DUSTER] #753879
07/21/10 06:08 PM
07/21/10 06:08 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
More arch on the springs.
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: joedust451] #753880
07/21/10 06:37 PM
07/21/10 06:37 PM
So am I gonna have to put 2"-3" blocks in to fix the problem??
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: MIKES_DUSTER] #753881
07/21/10 06:48 PM
07/21/10 06:48 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i would think you would be better off moving the shackle mount on the frame.
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: MIKES_DUSTER] #753882
07/21/10 07:42 PM
07/21/10 07:42 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
If it is anything like mine........1 " might be plenty. ( 1965 Dart )
I made boxes in the 3 " neighborhood and it was too much by a bunch.
That was with the 7/8ths offset kit.
I went to sliders when I moved the springs under the frame rails.
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: tubtar] #753883
07/21/10 10:52 PM
07/21/10 10:52 PM
I did buy new hangers from Firm Feel and we bolted the spings in the upper hole to bring the back of the car down.
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: MIKES_DUSTER] #753884
07/22/10 04:15 PM
07/22/10 04:15 PM
Hey Tubar...Can you post some pics of your shackles/sliders???
Re: PICS OF SHACKLES WITH SS SPRINGS. [Re: MIKES_DUSTER] #753885
07/22/10 05:00 PM
07/22/10 05:00 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Here ya go.
This is with the 3 " off set kit installed.
Page 1 of 3 1 2 3
