Re: wilson manifolds carb spacer question
[Re: wafflebatter]
#752550
07/19/10 04:03 PM
07/19/10 04:03 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
I had that very spacer a few years ago, nice piece, but it didnt do anything for me.
that said, every combo is different, you probably know that spacer might make a bit more torque, compared to your open that might help up top more, just depends on what you are looking for.
It was a very nice piece, sold it at Norwalk to somebody several years ago.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: rebel]
#752554
07/20/10 07:58 AM
07/20/10 07:58 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
i'm not sure about the wilson unit. i recently bought one of these penolic tapered spacers. it's a lot cheaper than the others. i wanted something to isolate the carb from the manifold & this fitted the bill plus it looked like it might do more than just be an isolator.
I like those, I wonder if they would have any positive benefits on a tunnel ram setup...??????
Rickster
[Re: rickstershemi]
#752555
07/20/10 08:39 AM
07/20/10 08:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have used a Wilson version one time it didnt help out for what I wanted... I have found that if you need the velocity the standard 4 hole works fine(low end torque) if you need the plenum volume the standard open works fine(top end HP) and no need for the fancy trick stuff.... JMO
[Re: MR_P_BODY]
#752556
07/20/10 09:41 AM
07/20/10 09:41 AM
Posts: 7,506 Az
Crizila
Az
I run one on a 408 with a victor 340 open plenum single plane. Kinda splitin hairs, but it looks like it improved my 60 foots by about .007 when I averaged a few of time slips.
Fastest 300
[Re: barryc]
#752561
07/22/10 01:15 AM
07/22/10 01:15 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Who makes that spacer and where did you get it? Thanks
sorry, don't know who makes this tappered spacer, i bought mine on an online auction & it came delivered in a bubblewrap courier bag.
[Re: barryc]
#752564
07/22/10 12:45 PM
07/22/10 12:45 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Ryan, I meant the green one that is posted. Wondering if putting the taper in the plenum will make a difference?
Sorry for the confusion, have not seen that design for sale, but yes they almost always make "some" difference. I have never put a tapered Spacer, whether it be an HVH or a Wilson on motor on dyno & not have it do SOMETHING positive.. gains like 15HP are rare. Normally you see 4-6 TQ/HP. Maybe 8-10 sometimes....
