wilson manifolds carb spacer question #752549
07/19/10 03:49 PM
07/19/10 03:49 PM
Fredonia,NY
W
wafflebatter Offline OP
W
Fredonia,NY
anyone tried or use a wilson manifolds 1" tapered carb spacer as sold at summit and what results did you get, just want to know if it is worth spending $120 if I wont see any results, I currently run just an open 1" phenolic spacer, thanks for any input!
Re: wilson manifolds carb spacer question [Re: wafflebatter] #752550
07/19/10 04:03 PM
07/19/10 04:03 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I had that very spacer a few years ago, nice piece, but it didnt do anything for me.
that said, every combo is different, you probably know that spacer might make a bit more torque, compared to your open that might help up top more, just depends on what you are looking for.
It was a very nice piece, sold it at Norwalk to somebody several years ago.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: wilson manifolds carb spacer question [Re: wafflebatter] #752551
07/19/10 05:10 PM
07/19/10 05:10 PM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
I have no idea about Wilson spacer but here is piece what has been dyno and track proven and really works : http://4secondsflat.com/carburetor_spacers.htm
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: wilson manifolds carb spacer question [Re: Georg] #752552
07/20/10 03:13 AM
07/20/10 03:13 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm not sure about the wilson unit. i recently bought one of these penolic tapered spacers. it's a lot cheaper than the others. i wanted something to isolate the carb from the manifold & this fitted the bill plus it looked like it might do more than just be an isolator.
Re: wilson manifolds carb spacer question [Re: rebel] #752553
07/20/10 03:30 AM
07/20/10 03:30 AM
K&Q va.
BIGBLOCK_KAT Offline
K&Q va.
Most of these spacers work with your camshaft design. overlap, etc. To help velocity & mixture.
Re: wilson manifolds carb spacer question [Re: rebel] #752554
07/20/10 07:58 AM
07/20/10 07:58 AM
Lehigh Acres, Florida
rickstershemi Offline
I like those, I wonder if they would have any positive benefits on a tunnel ram setup...??????
Rickster
Re: wilson manifolds carb spacer question [Re: rickstershemi] #752555
07/20/10 08:39 AM
07/20/10 08:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have used a Wilson version one time it didnt help
out for what I wanted... I have found that if you need
the velocity the standard 4 hole works fine(low end
torque) if you need the plenum volume the standard
open works fine(top end HP) and no need for the fancy
trick stuff.... JMO
Re: wilson manifolds carb spacer question [Re: MR_P_BODY] #752556
07/20/10 09:41 AM
07/20/10 09:41 AM
Az
Crizila Offline
Crizila  Offline
Az
I run one on a 408 with a victor 340 open plenum single plane. Kinda splitin hairs, but it looks like it improved my 60 foots by about .007 when I averaged a few of time slips.
Fastest 300
Re: wilson manifolds carb spacer question [Re: wafflebatter] #752557
07/21/10 08:47 AM
07/21/10 08:47 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
expensive yes,do they work yes me and ryan j put my 1" 4 hole spacer on and no bs 15hp on the dyno,also woke up my more mild 418 better 60ft 1.47 off the foot..its a nice spacer
Re: wilson manifolds carb spacer question [Re: rebel] #752558
07/21/10 09:46 AM
07/21/10 09:46 AM
New Jersey
barryc Offline
barryc  Offline
New Jersey
Who makes that spacer and where did you get it?
Re: wilson manifolds carb spacer question [Re: barryc] #752559
07/21/10 11:58 PM
07/21/10 11:58 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
wilson cnc 1" 4 hole on a 360-1 manifold with very basic ryanj port match!
Re: wilson manifolds carb spacer question [Re: barryc] #752560
07/21/10 11:59 PM
07/21/10 11:59 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
ps barry i know ur car from etown and atco..ITS KILLA!
Re: wilson manifolds carb spacer question [Re: barryc] #752561
07/22/10 01:15 AM
07/22/10 01:15 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
sorry, don't know who makes this tappered spacer, i bought mine on an online auction & it came delivered in a bubblewrap courier bag.
Re: wilson manifolds carb spacer question [Re: rebel] #752562
07/22/10 08:49 AM
07/22/10 08:49 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Um it's made by.... WILSON. Sorry had to be smart ass LOL.
http://www.summitracing.com/parts/WSN-004110/
Re: wilson manifolds carb spacer question [Re: RyanJ] #752563
07/22/10 09:53 AM
07/22/10 09:53 AM
New Jersey
barryc Offline
barryc  Offline
New Jersey
Ryan,
I meant the green one that is posted. Wondering if putting the taper in the plenum will make a difference?
Re: wilson manifolds carb spacer question [Re: barryc] #752564
07/22/10 12:45 PM
07/22/10 12:45 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Ryan,
Sorry for the confusion, have not seen that design for sale, but yes they almost always make "some" difference. I have never put a tapered Spacer, whether it be an HVH or a Wilson on motor on dyno & not have it do SOMETHING positive.. gains like 15HP are rare. Normally you see 4-6 TQ/HP. Maybe 8-10 sometimes....
Re: wilson manifolds carb spacer question [Re: RyanJ] #752565
07/22/10 11:14 PM
07/22/10 11:14 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
How about an air pan....
5.53 @ 125 1/8th on the launch control..more left in her!
Re: wilson manifolds carb spacer question [Re: RyanJ] #752566
07/22/10 11:24 PM
07/22/10 11:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ryan have you run a (we will say) a standard 4 hole
then run a tapered in a back to back on the dyno,
I'm sure it might be the added velocity in either
to get a better TQ/HP ... at least thats what I seen
when I was doing headers on the dyno but we played
with some spacer also but you have more dyno time
than I do
