Page 2 of 4 1 2 3 4
Re: Fuel Injection vs. Carburetor BB [Re: Magnum] #752099
07/19/10 04:18 PM
07/19/10 04:18 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
The only thing FI can do that a carb can't is to be able to make changes rapidly.
I have a running bet with people around here that I can take a factory fuel injection off of a modern car, put a carb on it and get better mileage. No one will take me up on it, but they say I'm crazy.
( factory FI keeps the A/F ratio at 14.4 , i can tune a carb near 15.5 for mileage.)
If you understand how a carb works you can tune any stumble out of it.
Re: Fuel Injection vs. Carburetor BB [Re: CurYellowBird] #752100
07/19/10 04:24 PM
07/19/10 04:24 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I looked at those parts you listed and is there a kit for a port injection setup rather than a TB setup?
The EZ for port injection is exactly that. All the port injected EZ system is, is the ECU and harnesses. You still need a normal TB and the port injection manifold.
Where are the injectors on that TB setup you listed? Are they below those mini fuel rails?
Yes. I think the photos of the EZ system are fairly easy to see where the injectors are. They are pointing down at an angle
Is EZ's EFI systems a closed loop system that uses sensors and what not to do self adjustments rather than having to constantly adjust an analog computer?
That's precisely what it is. You should go to my site and print out the EZ info. It runs in closed loop and is constantly learning as you drive.
Re: Fuel Injection vs. Carburetor BB [Re: fox] #752101
07/19/10 04:33 PM
07/19/10 04:33 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Yeah, but that's not 1 thing, that's like 1000 things - per second.
EFI can turn the fuel off completely on a downhill coast, then turn it on so seamlessly that you'd never know -- unless you saw it on the AF or MPG gauge. There's a 1/2 mile long hill on the highway where I usually get 150+ mpg for 30 secs. Try that with a carb. With a carb you're at closed throttle, high vacuum, and pulling fuel thru the idle circuit.
Re: Fuel Injection vs. Carburetor BB [Re: CurYellowBird] #752102
07/19/10 04:36 PM
07/19/10 04:36 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I looked at those parts you listed and is there a kit for a port injection setup rather than a TB setup? I looked at the last set you listed and it looks like just a wiring harness and some computer stuff.
I have not yet seen any port-EFI intakes for 383/400 engines. Getting a manifold modified will be your only option.
Re: Fuel Injection vs. Carburetor BB [Re: fox] #752103
07/19/10 04:52 PM
07/19/10 04:52 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I agree a carb can be tuned well, however an aftermarket efi system can be tuned to run at whatever cruise a/f you want. The OEM is stuck on 14.7 stoic because they have emissions standards to meet. I would guess you could tune a port efi system more lean than a carb if you have an intake manifold with low cylinder-to-cylinder airflow variances. You could have the same a/f ratio in each cylinder instead of dealing with the wet AND dry flow variances a carb intake experiences.
Re: Fuel Injection vs. Carburetor BB [Re: CurYellowBird] #752104
07/19/10 05:25 PM
07/19/10 05:25 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You won't gain one HP w/ FI and w/ well tuned carb that is correct for you application you won't suffer any drivablity problems either. EFI is nice but VERY expensive. any gain in MPGs (and who cares about that) would be so small it'd take you 10 years to get your money back. Unless you have a boosted car EFI is a waste of money
Coming soon!!!!
Re: Fuel Injection vs. Carburetor BB [Re: Mr.Yuck] #752105
07/19/10 05:29 PM
07/19/10 05:29 PM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
I would of done a poll on this but I can't figure out how to set one up.
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: Fuel Injection vs. Carburetor BB [Re: CurYellowBird] #752106
07/19/10 05:44 PM
07/19/10 05:44 PM
Denver
E
Explodo Offline
Explodo  Offline
E
Denver
A possible issue depending on your EFI fuel system PSI and car: A good fuel pump. The fuel system has been the biggest pain on mine. The EFI system itself isn't any trouble at all. I'm running a Mass-flo EFI system and have an Anderson Ford Motorsport computer to put on when I put it all back together because I hate that the Mass-flo system gives you zero feedback. The fuel system I've ended up with as an Aeromotive a1000 stealth sump built into a stock tank.
'67 440 Satellite
Re: Fuel Injection vs. Carburetor BB [Re: Mr.Yuck] #752107
07/19/10 06:01 PM
07/19/10 06:01 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
I know you're a huge proponent of carbs, and voice your opinion every time this debate comes up.
What I'd like is a definition of "drivability".
I consider the ability to drive from 10' above sea level to 7000' above sea level and have the engine perform (economy and power) exactly the same in both locations to be drivability. Show me a carb that can do that, and I'll agree there are no differences.
Re: Fuel Injection vs. Carburetor BB [Re: Pat_Whalen] #752108
07/19/10 06:45 PM
07/19/10 06:45 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You represent a small minority of car people who an EFI set-up would help, although you can tune a carb as well.
Re: Fuel Injection vs. Carburetor BB [Re: Mr.Yuck] #752109
07/19/10 06:52 PM
07/19/10 06:52 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Agreed. I wouldn't call it a small percentage, but a minority. I'm sure there are plenty of people who drive in a situation where they don't realize their carburetor is performing less than optimally.
If there is an arbitrary number (lets say 10) of things that a fuel delivery system should accomplish, optimally you'd like to see all 10 of those things be at their highest available values. And while there is a concession of initial system cost with EFI, there is no way that a carburetor can come close to matching it in all facets of the system. You could tune in 20 times a day and still not get it as mathematically perfect as an intelligent circuit would.
What is the potential negative of EFI, other than initial cost? I know you often cite complexity, but in reality, thats a misnomer. Hoping you've got the right combinations of screws turns in, rods bent, etc with a carb application is much less precise and can be considered much more complex than an electronic "on/off" and open modulation of air.
Re: Fuel Injection vs. Carburetor BB [Re: CurYellowBird] #752110
07/19/10 06:57 PM
07/19/10 06:57 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Carb or EFI
multiple choice
Votes accepted starting: 07/19/10 05:57 PM
You must vote before you can view the results of this poll.
Re: Fuel Injection vs. Carburetor BB [Re: CurYellowBird] #752111
07/19/10 07:17 PM
07/19/10 07:17 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
If you already have a carb( if i understand corectly you have a BG 750)put it on and run it. Spend the money instead on a Gear Venders overdrive. Especially considering you said that you plan on doing a lot of highway driving. You can always add EFI later if you decide you don't care for the carb.
Re: Fuel Injection vs. Carburetor BB [Re: OzHemi] #752112
07/19/10 07:17 PM
07/19/10 07:17 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Fuel Infection will never find it's way onto any old car I own.
I must be in the minority because I have had several carbureted vehicles as daily drivers and have not experienced all the incurable stumbling, bogging, stalling, ect. that everyone else talks so much about.
Re: Fuel Injection vs. Carburetor BB [Re: Neil] #752113
07/19/10 07:57 PM
07/19/10 07:57 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
I'd guess it's just a preference.
OE went to EFI who long ago? Top fuel dragsters use mechanical fuel injection. There has to be a reason to it.
Furthermore, I can only imagine (because I'm admitting to never having done it) how much "fun" it is to try and keep a carb perfectly in tune. By perfectly I mean a carb that complies with mixing any way you want it through every RPM and driving scenario.
A crank vs. power windows will both get the window up and down. How would you rather do it?
Re: Fuel Injection vs. Carburetor BB [Re: Neil] #752114
07/19/10 07:58 PM
07/19/10 07:58 PM
IN
ahy Offline
ahy  Offline
IN
Lots of good discussion. I'll add I run XFI on a 496B... why?
- Drivability
- Adaptability... straight gas no problem, 10% alcohol, no problem. 800' altitude no problem, 8000' altitude, no problem
- Fuel economy. I like to be able to drive my "hobby car" a good bit without a crazy gas bill or 30 gallon fuel tank. 14 MPG travelling but not babying it with 550 streetable HP on tap is worth something to me.
- Fun. I have enjoyed setting up and refining the maps in the XFI. If I didn't I would probably pick EZ EFI.
Re: Fuel Injection vs. Carburetor BB [Re: Neil] #752115
07/19/10 08:03 PM
07/19/10 08:03 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I had a nice running carb on my 440 before I went turbo. I put lots of time into the carb making it as perfect as it could be. All I had to do was hit the starter and it'd fire up every time.
If I wanted to lean it out to get better mileage, performance suffered. If I fattened it up to get power then drivability issues would arise and mileage dropped.
I was perfectly happy with the setup.
After going turbo, I fought with carbs. That never worked out for me so I went EFI.
As far as I'm concerned, I'll stick with EFI. You could say I'm fuel infected if you like but I'm happy with it.
I can lean it out as much as I like on the highway and still be fat and happy under power. There is simply no comparison.
There are better units than mine out there. They have more features and options. However, mine can still do the following:
1) Run any fuel air ratio I need at any rpm and manifold pressure (vacuum or boost)
2) Shut off fuel when coasting
3) Adjust timing for cruise, acceleration, coasting, boost, or vacuum
4) Adjust for hot or cold starts
5) Prime fuel system for any length of time desired
6) Display rpm, temperature, timing, manifold vacuum, level of detonation (if any), battery voltage, air/fuel ratio, throttle position, and fuel timing all in one screen
7) Knock sensor will detect any level of detonation and adjust fuel/spark immediately
8) Soft rpm limiter that pulls as much timing as I want, dropping the rpm any amount I want at the speed I want
9) Hard rpm limiter that cuts fuel for a banging style limiter
10) Hard limiter can be used as a two step box with a soft limiter on the top end
11) Cooling fan on/off where I want
12) Control a turbo wastegate
13) Control nitrous solenoids
14) Trigger a shift light
15) Record every sensor and engine function for any reasonable amount of time and play it back as fast or slow as I want
16) Print out graphics from the datalog
17) Download the datalog into spreadsheets so you can view them later.
18) You can adjust the tune while driving
19) Tune the car from the front seat instead of reaching across spinning fan blades and scorching headers
20) Upload an entirely new tune in less than 30 seconds if you want to run race gas
21) Automatically adjust for a tank of "bad gas"
It'll do other stuff as well but that's what I can think of off the top of my head.
Will your carburetor and distributor do all that for you?
Gimme EFI! I'm not afraid of change.
- Stu Harmon
Re: Fuel Injection vs. Carburetor BB [Re: feets] #752116
07/19/10 08:42 PM
07/19/10 08:42 PM
San Antonio, TX
San Antonio, TX
That EZ-EFI system really seems to be the best one for my planned setup and it's simple enough compared to holley's projunk.
My other option I'm looking into is swapping out the factory 4 speed for a 5 speed and then going with a 440. At that point it should be a little easier to find a port injection setup for a 440. But the costs and looks of the EZ-EFI is definately appealing.
Anyone know if you can use a stock dual snorkel air cleaner and edelbrock rpm intake with this setup without having hood clearance issues? I think since the TB is shorter than a carb I should have plenty of clearance....hopefully.
Re: Fuel Injection vs. Carburetor BB [Re: CurYellowBird] #752117
07/19/10 08:45 PM
07/19/10 08:45 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I think a lot of people have issues with carburetors because they are cheap and bought a used one at a swap meet and it was already messed up to begin with, or they buy a new one and take it from the box and bolt it on and then get angry when it doesn't work perfectly. I take every carburetor I buy and reset everything before bolting it onto the engine. Doing so doesn't always mean it's going to work perfectly, but it will almost guarantee the engine will run well enough to drive until I can fine tune the air fuel screws and jetting.
All oem the fuel injected cars I have driven have lots of gas pedal "slack" at a continious speed until the engine responds. A properly set up 4 barrel carb, especially a spread bore model, has a much better feel to it in my book when it's time to speed up and pass someone.
If FI is all that then why do a lot of the drag race guys trashcan the FI system on their 5.0 and camaros and replace it with a single plane and a big holley or demon carb?
Re: Fuel Injection vs. Carburetor BB [Re: Neil] #752118
07/19/10 08:57 PM
07/19/10 08:57 PM
San Antonio, TX
San Antonio, TX
Most of the time they trash their FI systems because they are modifying the car so much and making more power to the point where the stock computer cannot keep up with the demands of the motor.
The factory FI's on camaros were either a TBI or TPI setup. Those setups work well with a 305 or 350 making right around 300 or 325hp. After that, the systems can no longer keep up and the engine powerband falls flat on its face at 5500rpm anyways with those setups. The computers at that point, if stock, are POS anyways.
You can easily get a 350 to get 380hp on a good day, the problem is that those guys do all the mods and neglect the computer and FI system thinking "O it'll keep up fine", then they get pissed when it doesn't so they just throw a carb on it. It's like putting a 383 stroker in a car with 2.29 gears thinking your gonna pull 10 seconds in the quarter.
Your comparing a stock system that was meant for emissions and government standards to aftermarket systems that blow the stock FI's out of the water. I've never had a problem with my carb on my chevy, at the same time when I tested that projection system, I was blown away at how good the throttle response was compared to a carb. Yes the edelbrock carb I had was in perfect tune and I double checked before the swap so I could feel an unbiased difference if there was one.
Page 2 of 4 1 2 3 4
