Crash Course on Roller Rocker adjustment #751021
07/18/10 08:45 AM
07/18/10 08:45 AM
Mashpee,MA
mopar360 Offline OP
Can't start my lawn mower
mopar360  Offline OP
Mashpee,MA
Alright so i have a 1979 Chrysler 300 with a 360 Magnum and it has Roller Rockers, how do you adjust them??
All throttle...No bottle! 1979 Chrysler 300 (360) 1984 Chrysler 5th Avenue (318)
Re: Crash Course on Roller Rocker adjustment [Re: mopar360] #751022
07/18/10 09:21 AM
07/18/10 09:21 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
More info, solid or hydraulic?
Re: Crash Course on Roller Rocker adjustment [Re: CokeBottleKid] #751023
07/18/10 09:33 AM
07/18/10 09:33 AM
Mashpee,MA
mopar360 Offline OP
mopar360  Offline OP
Mashpee,MA
Uhhhhhhh...How do i find this out?
Re: Crash Course on Roller Rocker adjustment [Re: mopar360] #751024
07/18/10 09:37 AM
07/18/10 09:37 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
there is no adjustment on stock 360 lifters,,roller or flat tappet..NO adjustment..your 1979 should be roller ..no adjustment
Re: Crash Course on Roller Rocker adjustment [Re: mopar360] #751025
07/18/10 08:24 PM
07/18/10 08:24 PM
Detroit, MI
Detroit, MI
Find a rocker with the valve closed, push towards the pushrod side, if it squeezes a little it's a hydraulic... You should be able to tell immediately when the motors running though. If it's a little tappy then it's probaby a solid.
I'm guessing it's a hydraulic....
Don't listen to this guy .
Re: Crash Course on Roller Rocker adjustment [Re: CokeBottleKid] #751026
07/18/10 08:57 PM
07/18/10 08:57 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I sm sure the the guy that you are referring to not to listen to is interpeting it that the OP thinks that roller lifters in a magnum engine mean the same as having roller rockers. I am not so sure that that isn't what he thinks myself seeing that he doesn't even know how to tell if he has a hydraulic or solid cam or how to tell the difference.I wander if he has had the valve cover off to see what he has for rockers. Whether they are even adjustable or standard rockers.
