Which way does the lock ring turn on sending unit? #750856
07/17/10 10:07 PM
07/17/10 10:07 PM
Costa Mesa, California
michaelphbarnett Offline OP
Which way does the lock ring turn to loosen it to take the sending unit out on a '70 Barracuda?
Re: Which way does the lock ring turn on sending unit? [Re: michaelphbarnett] #750857
07/17/10 10:12 PM
07/17/10 10:12 PM
CCW
Re: Which way does the lock ring turn on sending unit? [Re: RapidRobert] #750858
07/17/10 10:31 PM
07/17/10 10:31 PM
Thanks. I put a light on it and figured it out. It helps when I can see what I am working on.
Re: Which way does the lock ring turn on sending unit? [Re: michaelphbarnett] #750859
07/17/10 11:03 PM
07/17/10 11:03 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
rightie, tightie, leftie loosie (at the top)
Re: Which way does the lock ring turn on sending unit? [Re: RapidRobert] #750860
11/07/12 10:23 PM
11/07/12 10:23 PM
Do you have to replace the gasket everytime?
Re: Which way does the lock ring turn on sending unit? [Re: michaelphbarnett] #750861
11/07/12 10:37 PM
11/07/12 10:37 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Not every time...But take a good look at the gasket...If it's expanded,degraded, etc... Just spend the few bucks and snag another..
Re: Which way does the lock ring turn on sending unit? [Re: screamindriver] #750862
11/07/12 10:44 PM
11/07/12 10:44 PM
Check/clean the metal surfaces that contact the gasket on each side. If a new one is needed get one that is the same or nearly the same thickness as the original one
