Re: Timing problem? Not so sure now
[Re: rtrag]
#750534
07/17/10 06:22 PM
07/17/10 06:22 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Looses all power and makes popping sounds until I let off the gas. I thought maybe it was not getting enough gas, but now I don't think so. It revs fine when the car is standing still. Its only when it is its being driven
Confirm float levels in the carb(s), accelerator pump operation, possible PCV valve malfuction, sounds like no advance of the ignition under increased RPM,....it's easy to blame, or find fault with componets in these situations, because they can mask themselves, and cause you to chase ghost problems, or create them,...start by confirming the function of the obvious, 1- air(vacumm included), 2- fuel, 3- spark, in that order
