Timing problem? Not so sure now #750529
07/17/10 05:44 PM
07/17/10 05:44 PM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
I had a 360 built for me by a reputable local guy.Someone else installed it. When I got it back, the car timed and ran okay until I drove it. Under load the car would crap out. With an easy gas pedal, it ran okay.Since, I have put in a compete MSD ignition and a new 650 edelbrock. It is still the same. It craps out when I step into it.....
Re: Timing problem? Not so sure now [Re: rtrag] #750530
07/17/10 06:02 PM
07/17/10 06:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Crap out is pretty generic so how about a better discription of what it's doing.
Re: Timing problem? Not so sure now [Re: stumpy] #750531
07/17/10 06:08 PM
07/17/10 06:08 PM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
Looses all power and makes popping sounds until I let off the gas. I thought maybe it was not getting enough gas, but now I don't think so. It revs fine when the car is standing still. Its only when it is its being driven
Re: Timing problem? Not so sure now [Re: rtrag] #750532
07/17/10 06:14 PM
07/17/10 06:14 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I have put in a compete MSD ignition and It is still the same. It craps out when I step into it.....
Well there's your problem right there!...MSD...(Might-Sputter & Die)
Sorry couldn't help myself,...but seriously, recheck your installation/wiring of the MSD,....take the time to reread the wiring instructions, eliminate any possible errors, seen way to many guys foul their ignition with a MSD installation, regardless of your experience, double check
Re: Timing problem? Not so sure now [Re: DAYCLONA] #750533
07/17/10 06:16 PM
07/17/10 06:16 PM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
The problem was exactly the same before I installed the ignition
Re: Timing problem? Not so sure now [Re: rtrag] #750534
07/17/10 06:22 PM
07/17/10 06:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Confirm float levels in the carb(s), accelerator pump operation, possible PCV valve malfuction, sounds like no advance of the ignition under increased RPM,....it's easy to blame, or find fault with componets in these situations, because they can mask themselves, and cause you to chase ghost problems, or create them,...start by confirming the function of the obvious, 1- air(vacumm included), 2- fuel, 3- spark, in that order
Re: Timing problem? Not so sure now [Re: rtrag] #750535
07/17/10 06:30 PM
07/17/10 06:30 PM
Under My Car
Mopar_Country Offline
Under My Car
I vote carb, sounds like it's running lean.
Re: Timing problem? Not so sure now [Re: DAYCLONA] #750536
07/17/10 06:31 PM
07/17/10 06:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you changed distributoors?
Re: Timing problem? Not so sure now [Re: stumpy] #750537
07/17/10 06:36 PM
07/17/10 06:36 PM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
Yup. Its all new.Nothing is any different
Re: Timing problem? Not so sure now [Re: rtrag] #750538
07/17/10 08:35 PM
07/17/10 08:35 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Sounds like fuel, but, what kind of distributor and is it vacuum advance?
Re: Timing problem? Not so sure now [Re: Cudajon] #750539
07/17/10 08:46 PM
07/17/10 08:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried reversing the two distributor pick up wires. I have seen this kind of thing caused by reversed polarity. Just another guess while we are at it.
Re: Timing problem? Not so sure now [Re: stumpy] #750540
07/17/10 10:20 PM
07/17/10 10:20 PM
Under My Car
Under My Car
I had the same problem with mine, mash on it and it would fall on it's face, easy steady pressure and it would go. It was way lean.
Re: Timing problem? Not so sure now [Re: Mopar_Country] #750541
07/17/10 10:22 PM
07/17/10 10:22 PM
vac leak
Re: Timing problem? Not so sure now [Re: RapidRobert] #750542
07/19/10 10:00 AM
07/19/10 10:00 AM
MI
Jerseyboy Offline
Jerseyboy  Offline
MI
I had this problem on my 68 Coronet when I got it. Ended up being too much initial ignition timing. When I would get on it the mechanical advance would over advance the timing and it would bbreak up. Car had 25degrees at idle with a standard mechanical distributer and lots of mechanical advance. What is your inital timing at? What is the max advance at 3400-3600 with the vacuum advance disconnected?
Re: Timing problem? Not so sure now [Re: Jerseyboy] #750543
07/19/10 03:53 PM
07/19/10 03:53 PM
P
Paul_Fancsali Offline
P
Years ago I had a 360 that did the same thing. Forget the 36 total and throw awy the edel carb, unless you can use a strip kit. Give the car all the total she can take up to 44 degree's or so disconnct the vac advance and leave it off. The MSD would be disconnected and a standard ignition put in its place Race parts on race cars it is evident that the car is not meant to race so get back to basic's. In the end if this does not work time to do basic diagnostic's. But from sound of it I tried like crazy to get my car to run using the Mopar bible spec's,it didn't, and I did my own thing. Good luck !
