What MSD doesn't tell you.
#747066
07/13/10 12:16 AM
07/13/10 12:16 AM
Posts: 112 Auburn Hills, Michigan
kieron_kohlmann
I posted this on the MSD page, but im sure it will get deleted. please note i experienced problem with a 7 series, but i hear a 6 MAY have problems too. So the source of my problem was this: I am using a Mopar Electronic ignition pickup. This pickup using a reluctor wheel thus producing a Sine Wave or Analog Pattern. The MSD 7 series in particular needs to see a Digital signal or square pattern to properly fire a cylinder. Anyone with an advanced knowledge of automotive electrical systems should know this. My question is why in your catalog does it clearly state: "It will accept trigger signals from points/ECU output or a magnetic pickup.". Due to your simple catalog error I have spend 2 weeks wasting time and money trying to figure out why my ignition wont work. Being the #1 Student auto tech in the nation right now i wondered how you could accurately send a signal to something as complex as a programable 7 with a sine wave. I trusted your catalog, since you hire engineers and other various electronic competent employees to perform your design/testing process. It baffles me to know that something so simple slipped by everyone there, including technical support; who insisted my 7530T was defective and had to be returned. OK, that understandable, so i buy a 7535 and install it. I still have the exact same problem, but i just spend another $700+$50 for shipping. Once again i call tech support and you insist i need a crank trigger. Why? you dont know; only because some guy in Russia had the same problem on a Monte Carlo. Nice. All i can say is there needs to be some clarification in your catalog as to the workings of an msd. I'm an 18 year old kid working at a Dodge Dealership and I can figure out why my ignition is screwing up and tech support is throwing out guesses, something is wrong with that picture. Please clarify your products so other people dont waste their time and money. Kieron Kohlmann 2010 SKILLS/USA National Winner http://racinepost-schools.blogspot.com/2010/06/kieron-kohlmann-wins-national.html
Re: What MSD doesn't tell you.
[Re: kieron_kohlmann]
#747069
07/13/10 12:31 AM
07/13/10 12:31 AM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
hi.. what was your problem with ignition?miss fires? ive always thought mopar dizzy to be same principle as crank tigger, instead little reluctor inside with 8 points to pass magnectic pickup. ive always used 6als with m/p dizzys, but ive never seen anyone with 7 series with stock type mopar dizzy, that could be why
MOPAR OR NO CAR
[Re: hemigod426]
#747070
07/13/10 01:49 AM
07/13/10 01:49 AM
Posts: 5,875 communist bloc of new jersey
jamesc
MSD = Mighty Stupid Design. yes i know they're the leader in automotive ignitions but i've never cared for the way they package their stuff. imho holley had the right idea way back when and i still use their ignitions but they just couldn't compete with msd. i'm not an engineer so i can't speak at that level. most digital stuff wants to see a square wave but afaik they can condition the sine signal and basically make it a square wave. when holley was doing their ignitions i was in close contact with the factory for a number of reasons. there was a change in the management so i ended up dealing with a different person that commented the previous individuals were OK with using a sine wave to trigger the digital but he was against it and felt it MUST be a square wave so you would need a hall effect or similar. i did get a couple hall effect sensors but never installed them as i have never had any problems with the standard sine wave magnetic pickup triggering the ignition. personally i find it hard to believe msd would design their digital ignitions so they only accept a square wave input given that most "triggers" used would probably be sine wave. i would "think" with all the R&D and engineering they have at their disposal they would have designed their digital ignition to accept a sine input but what do i know. on another note imho i wouldn't be using a stock mopar distributor to trigger an ignition of that caliber anyhow as it kinda defeats the purpose. one thing to be cautious of is trigger polarity, get it backwards and they can do all kind of strange things. on another note and don't take it personally, coming off cocky like that isn't the best way to go about things. yes you won a bunch of awards but remember this quote and it's meaning "If I have seen further it is only by standing on the shoulders of giants" you weren't born with that knowledge...someone gave it to you. fwiw my father taught auto shop at a high school and vocational level for 20 years
[Re: Monte_Smith]
#747074
07/13/10 06:24 AM
07/13/10 06:24 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
A digital 7 box works fine with a mopar magnetic pickup distributor, you have another issue.
Monte
X1000 Look else where.
[Re: Monte_Smith]
#747075
07/13/10 07:18 AM
07/13/10 07:18 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Monte
^^^^^^^^^What he said.....I know many guys running the Dig-7 with magnetic pickup dizzies
One thing to look out for is that you don't run the trigger wire next to or parallel with any power source wiring
Rickster
[Re: rickstershemi]
#747076
07/13/10 07:53 AM
07/13/10 07:53 AM
Posts: 798 Houston TX
GregCon
Houston TX
MSD is a so-so company. You can look to see where they are located and that should tell you plenty.
That said, there's no reason a digital device can't work off a sine wave. It happens millions of time every day in all sorts of applications. Don't forget, almost (and I mean basically all) AC power is sine wave power and there are hundreds of thousands of digital devices working in harmony with them. I'd bet a Hemi Daytona your house is powered by sine wave power that is regulated by digital controls.
Do you mean it won't work at all, or it won't work properly? Does the car start and run poorly or not at all?
[Re: jamesc]
#747078
07/13/10 08:17 AM
07/13/10 08:17 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
.."trigger polarity...". VERY important! I've been told by many that it makes no difference...BUT, I KNOW from past experiences that MSD must have a color blind person putting the leads in the connectors. I have recieved units wired wrong at the connectors and it will cause a bunch of different conditions, from no start, hard start, start OK but break-up at higher RPM's, irratic timing light, etc.
If you like drag racing, support your local track.
[Re: GregCon]
#747080
07/13/10 08:59 AM
07/13/10 08:59 AM
B G Racing
Eighty Four, PA
I say MSD is so-so because their products suffer from poor QC, as others note, and their support is not so great either.
I've had an MSD 6 AL that would 'stop' all of a sudden, then 'start' again, all while I was sitting on the side of the road. I sent the box back and they charged me $50 to 'fix' it. I asked if they found something wrong and they said 'yes'. I asked what and they said (get this...) 'whatever it was that was causing it to stop working'.
Sure enough, I continued to have the same problem, only my wallet was $50 lighter.
"So-so" is what they get. When they move from Northern Mexico to somewhere where electricity is understood they might get better.
Good product,bad quality control like most all big companys today.It's "people problems" there are no conciencious craftsmen in the work place anymore.Look at most every successful manufacture and listen to all the complaints about quality control and service from the end users..
[Re: GregCon]
#747081
07/13/10 09:13 AM
07/13/10 09:13 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I had a high rpm miss that was driving me crazy and finally changed to my spare 7al box... problem was gone so to verify the problem I put the box back on and the problem was back (I did this 3 times to verify) and sent the box back to MSD.. they told me nothing was wrong with it BUT when I got it back the problem no longer was there with the box(I cant say for sure if they sent me a different box or not... I didnt have any special mark on it).... in the end would I junk my MSD stuff for 1 problem... let me think... NO
[Re: Monte_Smith]
#747082
07/13/10 09:15 AM
07/13/10 09:15 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Monte
I agree. That's exactly what was on my last race car. No issues at all. Sometimes a little knowledge is a bad thing.
[Re: B G Racing]
#747083
07/13/10 09:18 AM
07/13/10 09:18 AM
BobR
Left Coast
MSD is a so-so company,well they have pulled of one of the most successful hoaxs perpetuated on the racing community in years.I would call that "success".Some of my 7-ALs are over 20 years old and still working,even those with Mopar distributers.We don't claim to have won any awards but our reputation,customer base and profit statements speak volumes and may be part of the reason we have survived in the business for 50 years. BGR"racers helping racers" Just thought we would do a little horn tooting for the crew of "Misfits"
Yep BG. I don't know why the bad rep for some guys but there is no better ignition either now or on the horizon. They are the absolute cutting edge leader in this area.
[Re: BobR]
#747084
07/13/10 09:36 AM
07/13/10 09:36 AM
B G Racing
Eighty Four, PA
Monte
To qoute someone smarter than me"We all judge ourselves by what we think we know and who we think we are,others judge us from what we have accomplished in life"
[Re: B G Racing]
#747085
07/13/10 09:45 AM
07/13/10 09:45 AM
BobR
Left Coast
Monte
That's one to remember.
[Re: CHAPPER]
#747088
07/13/10 12:13 PM
07/13/10 12:13 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I 2nd this, I've had the same issue with my MSD 6. The polarity of the wires from the dist must be right for some units to work...
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Cudajon]
#747089
07/13/10 12:14 PM
07/13/10 12:14 PM
jamesc
The important thing is that the sine wave goes above whatever voltage threshold to signal a 'high', and then that it goes below another lower voltage to signal a 'low'. It also has to stay above the 'high' voltage long enough for the electronics to detect it. (Same with the 'low' voltage).
exactly, i do believe they can select on which side of the slope it triggers as well. there may be more "noise" considerations with sine but you could get noise on a square system as well.
[Re: Cudajon]
#747090
07/13/10 12:29 PM
07/13/10 12:29 PM
B G Racing
Eighty Four, PA
Generally we find most ignition problems are caused by interference,incorrect installation,backfeeds from other electronics,poor grounds,resistence, and plain stupidity.Without mentioning any names,we know a guy that destroyed a $30,000 engine cause he was so bright that he programed his racepac system and it would advance the timing 10 degrees for every 1000 rpms,so the initial timing was at 35 degrees at 1000 rpm, you do the math at 8000 rpm.He blame everyone from the engine builder to every parts manufacture involved including MSD.Look at the basics here,distributer was locked and timing was set at 35*(can't change),timing gears and chain is fixed(can't change),ignition box can only be controlled by imput,imput was controlled by racepac.Guess who was the Einstein who had their laptop hook to the racepac.Sometimes basic logic escapes common sence and the "Einstein" wants to bash and blame everyone else.I was at a football game and was watching the band at halftime,when I heard a mother standing near me comment that her son was the tuba player and as I watched him trip and stumble down the field,she commented:"look how bad the band is out of step with my son"
[Re: B G Racing]
#747091
07/13/10 12:29 PM
07/13/10 12:29 PM
Posts: 7,506 Az
Crizila
Az
Most the people putting the stuff together today can't even spell craftsman. In todays environment, you don't want to buy anything that comes out of Mexico if you can help it.
Fastest 300
[Re: Monte_Smith]
#747094
07/13/10 01:49 PM
07/13/10 01:49 PM
B G Racing
Eighty Four, PA
OK, name an ignition system you think is BETTER than MSD and tell us why....not just because you say so.
Monte
W&H Daul Coil and Fairbanks Morse if we were back in the 1950s Just kidding Monte,I want to see if I could sound as stupid as some of the brilliant comments.Barry Grant,Indy,MSD and many others get bashed cause of someones fkups.Usually if someone has a ligitimate claim the manufactures bend over backwards to help.Most issues is caused by frustration and attitudes.
[Re: B G Racing]
#747095
07/13/10 01:59 PM
07/13/10 01:59 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
I have been running MSD products for decades. Never had an issue. Even sent an old 7AL in for upgrades and rev limit install and check a 2 Step. They did the upgrades installed a rev limiter and sent a NEW 2 step for the huge sum of 85.00 with shipping. I have also used MSD's with the MP type distributors with zero problems.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#747096
07/13/10 02:07 PM
07/13/10 02:07 PM
B G Racing
Eighty Four, PA
I think you are part of a conspiracy put in place by MSD.A sleeper cell do you know any Robert Frost poems hidden in your subliminal mind?
[Re: GregCon]
#747100
07/13/10 02:33 PM
07/13/10 02:33 PM
Posts: 705 Michigan
Hemiroid
I love the posters who think they can win an argument by calling someone crazy. You guys have it figured out - I have been lying all along about my MSD failures in order to cover up my involvement in the Kennedy/Oswald matter.
Now for the adults on this BB....
In a sense, MSD might well be the best aftermarket ignition by default - but that doesn't hold them above criticism.
If we use reliability as a main criteria, then just about any OEM offers a better product. I have never seen a contemporary GM, Ford or Mopar ignition fail to produce spark. True, they won't spin to 10,000RPM but that ability doesn't mean much of you can't get to the first 1,000RPM.
I'll also bet the ignition provided by a Motronics or FAST box is far better. The truth is the automotive world begs cheapness. When you are selling a box for $500 you won't be able use the best of anything in it. If heavy industry used ignition boxes you'd see $15,000 boxes that never, ever failed.
If you haven't seem OE ignitions fail and not provide spark then you might want to back out of this discussion due to a lack of information and real world experience.
[Re: GregCon]
#747101
07/13/10 02:45 PM
07/13/10 02:45 PM
B G Racing
Eighty Four, PA
At the risk of being imature,we have over 500 units of specialized equipment for construction,mining and tunneling with ECUs that have vary sophisticated functions and have to work in unbelivable conditions.On some $15,000 wouldn't cover the cost of a technician to come from Germany or Sweden to trouble shoot them let alone replace them.I would file it under shtz happens,as nothing is guaranteed to be perfect and last a lifetime.I'am in the "heavy industry" and know the cost of flying in emergency parts and it pales in compariason to "down time" cost. Sorry you don't like our light hearted humor.
[Re: Hemiroid]
#747102
07/13/10 02:52 PM
07/13/10 02:52 PM
BobR
Left Coast
Beat me to it. Hemi heads are junk for top fuel too. The only reason EVERYONE uses them is because there's nothing better.
[Re: B G Racing]
#747103
07/13/10 03:03 PM
07/13/10 03:03 PM
sixpackbee
Western New York
At the end of the day it all comes down to "we", corporations as well as indviduals, can not and will not ever bat 100%. There will be some unfortunate folks that get that bad widget that came down the line. If it is one in a thousand that day I would rate that as pretty good.
[Re: Crizila]
#747106
07/13/10 04:09 PM
07/13/10 04:09 PM
BobR
Left Coast
There was an old man from Kent,.....
U mean Nantucket!
I heard about that dude...
[Re: GregCon]
#747108
07/13/10 04:34 PM
07/13/10 04:34 PM
Quicktree
As for "MSD is the most successful so that makes them the best" let me list a few others that would fit into that category:
Chevrolet (in the 1960's) Microsoft GE Michael Jackson Jesse Jackson Oprah Winfrey AT&T
So we see that the skill of learning how to be sucky and make people still buy your product is not to be confused with 'best'.
where did you come from? ever think about going back
[Re: MR_P_BODY]
#747110
07/13/10 05:10 PM
07/13/10 05:10 PM
Posts: 3,160 L.I. N.Y. Hemi Street
HemiGreg
well as a student of auto electronics, take this exp as a learning curve. nothing else. like BG said every Co has its kooky mgrs and workers who only look out for the bouns. anyway the problem at hand is your sine input Vs the needed digital. you dont explain if you need a leading edge and at what level of triggering was required. a simple lookl with an O scope will clear that up. asle a clamping diode will clean up your rising and falling edges of the pulses. ive fixed dozen ignitions and every unit has different "clean" input requirements. im sure since you are top dog student you realized you probably got a magnetized reluctor by some dummy using a steel feeler gauge and therefore providing that sine magnetic pulse. check it with a gauss meter and let us know. you can fire a digital with a 45% slope on input sooo something is not right in whooville today.
[Re: BobR]
#747111
07/13/10 05:39 PM
07/13/10 05:39 PM
CHAPPER
Belpre,Ohio
"There once was a hermit named Dave who kept a dead---in his cave,"
[Re: Monte_Smith]
#747113
07/13/10 05:44 PM
07/13/10 05:44 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Monte
I think the Crane HI-7 and HI-8 ignitions with the DEC9500 boxes were the best when they came out 10+ years ago, and still work as good if not better than any MSD units. It's really too bad Crane didn't market those any better, they are very dependable. Alot of the Pro Stockers used them until they were mandated to use the MSD 7530T ?? box. I know Warren Johnson used Crane till the very end.
Anyway, I still use my Crane with no issues, after getting rid of my MSD which always had issues. I have two spares, so I'm good till I die..
Chris..
[Re: B G Racing]
#747114
07/13/10 05:55 PM
07/13/10 05:55 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Oh man ............ that is the funniest bit of writing I have put eye to in a good bit. Way funnier than I expect from a " serious " forum like this. Bob , I'd love to expound on your comedic brilliance some more , but as you well know , The woods are lovely , dark and deep. But I have promises to keep......and miles to go before I sleep.
Miles to go before I sleep.
Nope , not a Frost fan per se , but a huge Charlie Bronson fan.
[Re: B G Racing]
#747121
07/13/10 09:09 PM
07/13/10 09:09 PM
Posts: 487 Charleston, SC
SCDaytona
Charleston, SC
Monte
You've got to be kidding about Barry Grant.
[Re: sshemi]
#747125
07/14/10 03:50 PM
07/14/10 03:50 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
My take on MSD is this. Over the years i have had a few MSD boxes, and for the most part they have worked fine. I did have a problem with a 6AL a few years back, that i proved was in the box, but hey, stuff breaks, nothing is infallible. What MSD enjoys is a virtual stranglehold on the performance ignition market.Its a niche market that they OWN. Pretty much any magazine you look at, the various prices you see they're stuff listed for are identical, same pretty much with Jegs, summit and everybody else, with very rare exceptions. As they have hardly any competition, and its unlikely anybody is going to step up and spend the R&D and initial investent and marketing money to challenge them, its very likely the generally poor customer service they provide will ever get any better. Why would it, no other company makes a similar product that would force MSD to keep they're feet to the fire from a " treating customers great" standpoint. Its kinda like the car business 25 years ago, only the domestics were out there, and say what you will, quality was many times lacking. With the Japanese and everybody else now offering cars here, it has " forced" the product across the board to be better. Its just a plain old fact that that is how it is. MSD has nobody, competition wise, to force them to do the above. Its actually somewhat of a feather in they're cap that the products are as reliable as they are with this being the case. Long story short, they aint perfect, and they are a little crusty to talk to, but they own the only game in town Kinda like Indy in some ways
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
