build sheet #74656
06/16/08 08:36 PM
06/16/08 08:36 PM
Flint MI
76michmac Offline OP
Flint MI
is it posible to get a build sheet just from VIN?
Re: build sheet [Re: 76michmac] #74657
06/16/08 08:50 PM
06/16/08 08:50 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
No
All the VIN will tell you is the year, body style, engine CID, assembly plant(I think) and build #. All of the other options are on the fender tag and build sheets.
Re: build sheet [Re: burdar] #74658
06/16/08 11:19 PM
06/16/08 11:19 PM
dogdays Offline
dogdays  Offline
broadcast sheet
Re: build sheet [Re: dogdays] #74659
06/16/08 11:25 PM
06/16/08 11:25 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Only if someone else just happens to have it. Even then, proof the car exists & proof of ownership is normally required, a VIN by itself is not enough.
