vapor lock / carb boiling in the bowl how to tell diff?
#74546
06/16/08 03:36 PM
06/16/08 03:36 PM
My 65 dart /6 with a 1 barrel Holley has had what appear to be vapor lock problems. I've recently learned that boiling in the bowl in the carb is similar.
How do I tell the difference when it is happening?
Re: vapor lock / carb boiling in the bowl how to tell diff?
#74547
06/16/08 03:42 PM
06/16/08 03:42 PM
RapidRobert
not sure but the /6 heat risers divert WAY too much heat.I would turn the counterweight "off"(I forget which way that is) & lock it there.
[Re: GO_Fish]
#74549
06/16/08 04:59 PM
06/16/08 04:59 PM
I knew they were the same thing but different locations. I want to know how to tell the difference since they would require different fixes.
#74550
06/16/08 06:27 PM
06/16/08 06:27 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
My experience with boiling in the carb is that you can hear it boiling a minute or two after engine shut down (at least on a small block).
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: DartGTDan]
#74552
06/16/08 08:02 PM
06/16/08 08:02 PM
RapidRobert
are you running "gasahol"(10% ethanol,90% gasoline).
