Page 3 of 3 1 2 3
Re: ubly results [Re: mopar dave] #745391
07/16/10 03:32 PM
07/16/10 03:32 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
went to a size hotter plug(ngk r5671a-7),i had autolite (ar3934) and jetted 4 jets leaner and went for a 5 mile ride down 75 and it felt great. no popping or surging and ran clean,it sounded crisp and clean. heres a pic of the #1 plug when i got back.
Told Ya!! Plug looks alot better, I should be the one to talk about leaning out in the heat , i'm still running fat & my plugs are Dark, i need to lean mine out, Now what you should do is go back to that colder plug, its best to run as cold as possible without fouling
Dave, whats your compression? You may want a -8 if its 11.5-12.5, but thats with iron heads, Try jetting down a bit more like 2 & 2, that plug looks really good, but still a tad rich, you'll know/feel if you went too far, it just won't pull quit as strong, then just jet back up, of coarse track testing is best, but if you know how your car feels (which you should), it won't be hard to notice the differences
Re: ubly results [Re: joedust451] #745392
07/16/10 05:03 PM
07/16/10 05:03 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
compression is 10.6 to be exact.
Re: ubly results [Re: mopar dave] #745393
07/17/10 09:04 AM
07/17/10 09:04 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
the scoop catch'es the air but barely. heres a pic.
Excellant work with pic. Now you know you have a variable if/when you are chasing jetting anomalies and ultimately performance. Now if you factor-in the lift the hood sees at speed you may be ok, MAY, I say. The worst scenario would have the airstream siphoning air from the scoop/carb but, you should be ok, SHOULD. Have I beat a dead horse enough? LOL. For certain, (8 o'clock day one!) I would seal or at least isolate the carb from the incoming radiator air (mixture).
Re: ubly results [Re: HardcoreB] #745394
07/18/10 10:09 AM
07/18/10 10:09 AM
Mt Morris Michigan
Mt Morris Michigan
i going to see if there is a way to glue a piece of medium sheet metal to the hood to seal it up. maybe liquid nails or something like that. any idea's you can give? does anybody make something for the six pack hoods to seal them up? maybe i could just glue some foam to the hood and make a sheet metal plate to mount on the carb,but then i'd have to figure out how to get a 4" filter in there.
Re: ubly results [Re: mopar dave] #745395
07/18/10 11:05 AM
07/18/10 11:05 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
I have the same car as you, same hood. I took some sheet metal from a fellow dirt track racer, don't recall the thickness, but it's pretty thin. Cut it square, made template for carb and drilled holes for the bowl screws. Then bought some aluminum angle from Home Depot, riveted to the sheet metal. Also riveted my bottom piece of air cleaner to the sheet metal. Bought the Moroso foam, cut and glued to length. I'll try to take some pic's this afternoon.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: ubly results [Re: ChrgrCuda] #745396
07/18/10 11:55 AM
07/18/10 11:55 AM
Mt Morris Michigan
Mt Morris Michigan
yeah, i'm interested to see how ya did it.
Page 3 of 3 1 2 3
