Roller 360 years? #74500
06/16/08 01:15 PM
06/16/08 01:15 PM
Buffalo, MN
hydro Offline OP
super street
hydro  Offline OP
super street
Buffalo, MN
When did the 360 engine start using a roller cam, and what was the window until until the "Magnum" re-design. I'm looking for a "LA" series motor that has the roller cam.
Also, is there any way to tell if the engine has the roller cam without tearing it apert in the salvage yard?
Re: Roller 360 years? [Re: hydro] #74501
06/16/08 01:20 PM
06/16/08 01:20 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
89-91 FI 360's
Pull the distributor and look down the hole. No major teardown necessary.
Some other 360's that weren't rollers may have bosses for holding down the spider.
Re: Roller 360 years? [Re: hydro] #74502
06/16/08 01:42 PM
06/16/08 01:42 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
1989-1992 LA 360s were rollers. Magnum 360s started in 1993 - one year later than the 318s.
Here is a nice site with info: Sorting Out: Chrysler’s 238, 318, 360 Engines
Re: Roller 360 years? [Re: Reggie] #74503
06/16/08 02:14 PM
06/16/08 02:14 PM
Buffalo, MN
hydro Offline OP
super street
hydro  Offline OP
super street
Buffalo, MN
What do I look for when I have the distributor out?
Re: Roller 360 years? [Re: hydro] #74504
06/16/08 04:11 PM
06/16/08 04:11 PM
scratchnfotraction Offline
look down the dist hole at the end of the cam and lobe
want to see a roller lifter on the cam lobe
want to look at the vally were there will be a thin metal hold down that hold the dog bones on the lifters
an 88 block may have the taller lifter bores and hold down bosses and have a flat tappet cam,so look at them if ya get a chance
if ya get a roller cam ya can reuse the roller lifters, take them apart and clean them
whatch roller cams and the springs...the cams fine but most use double springs...get a single with a damper that drop on with no machine work
I have an extra set of doubles springs now
Re: Roller 360 years? [Re: scratchnfotraction] #74505
06/16/08 04:44 PM
06/16/08 04:44 PM
Buffalo, MN
hydro Offline OP
super street
hydro  Offline OP
super street
Buffalo, MN
Thanks for the info!
Re: Roller 360 years? [Re: hydro] #74506
06/16/08 05:41 PM
06/16/08 05:41 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
As said 89 - 91 360's. I was told if it has TBI its a roller. Mine was. It should also have some 308 heads as a bonus. Good Luck.
Steve
Re: Roller 360 years? [Re: srunge55] #74507
06/16/08 09:06 PM
06/16/08 09:06 PM
Deweyville, UT
RUDF1 Offline
super gas
RUDF1  Offline
super gas
Deweyville, UT
Link from reggie says a 92 has old style inside, but pad and ears on outside, and that 92-97 uses same block, but Magnum started 93, so did head bolt pattern change 93-97, even though block # is the same as 92?
Is a 92 a 93-97 block but still uses LA head bolt pattern, then later years just drill head different, or is a 92 not useable with LA heads?
1971 Dart GT 1973 Dart Swinger
Re: Roller 360 years? [Re: RUDF1] #74508
06/16/08 11:18 PM
06/16/08 11:18 PM
dogdays Offline
dogdays  Offline
LA and Mag heads are bolt-on interchangeable as far as the block to head. Intakes, rocker oiling, etc are different but no difference in the head bolting to the block. There are some problems trying to get a later block to get oil up to the LA rockers, I think that's what you saw in the link. The real question is why one would want to put an LA head on a Mag block unless they were W2s or something like that.
R.
Re: Roller 360 years? [Re: dogdays] #74509
06/17/08 02:24 AM
06/17/08 02:24 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
I want one too! Too much money for the retrofit lifters. Mike
Re: Roller 360 years? [Re: mopars4ever] #74510
06/17/08 07:34 AM
06/17/08 07:34 AM
the house on the left.
cogen80 Offline
cogen80  Offline
this is what you will see under the intake.
Re: Roller 360 years? [Re: cogen80] #74511
06/17/08 08:33 AM
06/17/08 08:33 AM
wont be clean and dry like that either
thats purdy
sorry
