Page 1 of 7 1 2 3 4 5 6 7
Im being harassed for wanting a Dana 60 in the Cuda. #745050
07/10/10 10:34 PM
07/10/10 10:34 PM
Rancho Cucamonga, Calif.
P
PUNK Offline OP
PUNK  Offline OP
P
We have been checking the prices to get rid of the 8 3/4 in the Cuda when we swap the new engine into the Cuda. The current 8 3/4 just has a Richmond spool and gears and budget Moser axles. The Dana we are looking at is a Strange S60 with 35 spline axles, richmond spool and gears with a standard chrome cover. Everyone I talk to is saying.."The only people that run a Dana are people that HAVE to run a Dana." Well, the 9 inch option seems to be MUCH more costly. I could care less about the ease of swapping third members. We have NEVER broken at the track and would like to keep it that way. Lets hear some opinions and the +/- of Dana vs. 9 inch.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: PUNK] #745051
07/10/10 10:46 PM
07/10/10 10:46 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
I like the Dana, they came out in mopars and are reasonably priced, very strong, brakes are interchangable and just look bad from behind.
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: PUNK] #745052
07/10/10 10:46 PM
07/10/10 10:46 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Don't listen to them. put a dana in it and forget about it..
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: 572B1] #745053
07/10/10 10:49 PM
07/10/10 10:49 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
...."they look BAD from behind."
If you like drag racing, support your local track.
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: PUNK] #745054
07/10/10 11:03 PM
07/10/10 11:03 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Dana = no worries.Install it and forget it.
Nautilus Racing-
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: Chris2581] #745055
07/10/10 11:12 PM
07/10/10 11:12 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
Three good reasons to use a Dana:
A Dana is lighter than people think it is.
A Dana has a higher pinion center than a 9"; the 9" has one of the lowest pinion centers of all. When it comes to pinion center, lower is worse.
God uses a Dana.
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: Chris2581] #745056
07/10/10 11:15 PM
07/10/10 11:15 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The only thing I don't like about the dana 60 is the cost to rebuild the posi. Seems I killed it every year, but might have been the crappy SS springs. Either way, I put a spool in it, and no more rebuilds needed. If your not going to put a spool in it, I would run the 9". If your its a spool application only, then which ever is cheaper, or if the dana's width gets in the way of mounting wheelie bars or something like mine nearly did, it was real close....
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: CHAPPER] #745057
07/10/10 11:15 PM
07/10/10 11:15 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
The Dana 60 is super beefy right out of the box. It doesn't need beefing up like the Ford 9" does. I'm sure the stamped sheet metal housing of the 9" is lighter, but the extra weight of the Dana doesn't appear to hurt performance. If anything, the extra weight right on the back tires might help traction a little bit.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: DusterDave] #745058
07/10/10 11:17 PM
07/10/10 11:17 PM
San Clemente, ca
enelson Offline
mopar addict
enelson  Offline
mopar addict
San Clemente, ca
I got a 3.91 in my dart and need a dana, and have yet to change to a smaller 3rd to go "drive on the street"
Granted it's not a 4/5.x gear but I have 26" tires so it is steep with my converter still....
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: GregCon] #745059
07/10/10 11:25 PM
07/10/10 11:25 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I really like the Dana. The 8 3/4 has kind of one advantage which is the ease of the swap. But I say Kind of cause I have found it not really a problem, cause I havent ever broke one so no need to worry about it. (knocking wood). So its not that big of a deal, unless one likes to experiment with gear swaps etc.
I bet the last two Dana's I have built didnt cost me $1300-$1400 for both combined.
I just used a Truck Dana, used old 8 3/4 ends so I didnt buy any new ones either. Picked up a ring and pinion, and spool from a swap meet for $175. I did order new Strange 35 spline lightened axles which fit my narrowed rear-end specs. Even took a stock cover, cleaned it up a little and painted it with some very Nice paint Aluminum Blast. Picked up some new GM metric calipers for a mid 80's S-10 and a set of Jeep rotors and made me some brackets for a very effective and cheap rear disc brake setup.
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: PUNK] #745060
07/10/10 11:31 PM
07/10/10 11:31 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
With Mark Williams 40 spline gun-drilled axles, aluminum spool and Aerospace
disc brakes, mine weighs 15 lbs. less than my 8 3/4" did with 11" x 3" drums.
I forget what the T/A cover weighs but, I think like 15 lbs.
Mine came out of a truck with 5/16" wall axle tubes.
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: S/ST 3040] #745061
07/10/10 11:57 PM
07/10/10 11:57 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
9" and 9.5 , is the rear end of choice for 98% of pro stock ,promod ,outlaw 10.5 and top sportsman cars .
You guys must know something that they don't.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: GregCon] #745062
07/11/10 12:01 AM
07/11/10 12:01 AM
P
PUNK Offline OP
PUNK  Offline OP
P
God uses a Dana.
Thats funny right there. OK, you convinced me. Im going DANA 60. LOL!
I know of 2 people personally that switched to a DANA from a 8 3/4 and lost NOTHING in performance. Which coincides with much of what Ive read. I need to get ahold of DR. Diff and get a price and ask him some questions about options.
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: go green] #745063
07/11/10 12:09 AM
07/11/10 12:09 AM
P
PUNK Offline OP
PUNK  Offline OP
P
I completely understand this. If I was building a car like you have listed I would definitely go that route, but for a cost effective Street/Strip application on a budget, Im hoping the Dana would be the choice. My friend Rons Valiant has a Mark Williams 9" and it is LITE to say the least, but a little too pricey for us. The new engine should have a little more than 650hp and we dont need every .001 of a sec. The car isnt getting completely caged, so we need to keep it 10.0 and slower. We just want it to go 10.0 at a high elevation, hot temp track and 10.0s with the power turned down at a good track.
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: go green] #745064
07/11/10 12:15 AM
07/11/10 12:15 AM
S/ST 3040 Offline
S/ST 3040  Offline
I'm going to go out on a limb here and say this.....
Mine was still cheaper.
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: S/ST 3040] #745065
07/11/10 12:20 AM
07/11/10 12:20 AM
SoCal
Brian Hafliger Offline
SoCal
Got a dana in my duster. I never worry about breaking!!
Brian Hafliger
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: Brian Hafliger] #745066
07/11/10 12:35 AM
07/11/10 12:35 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Do the Dana!!!
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: RobX4406] #745067
07/11/10 12:52 AM
07/11/10 12:52 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
You do what YOU KNOW is right- anybody giving you a hard time about wanting to use the dana should go pound sand.
I'm in the same boat as you with my new mill coming and having similar performance expectations- I can guarantee you there will be a dana in there as soon as the money tree blooms again.
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: 72demon416] #745068
07/11/10 01:34 AM
07/11/10 01:34 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
DAAAANA...DAAAANA...DAAAANA...DAAAANA...DAAAANA...
Under the coronet...
Re: Im being harassed for wanting a Dana 60 in the Cuda. [Re: go green] #745069
07/11/10 01:36 AM
07/11/10 01:36 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
for those classes yes, but a low to mid nine sec car, id go dana, that MW rearend is at least 4-5 grand mabey more
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
