factory tach disturbutors, how does the wire go? #74475
06/16/08 12:54 PM
06/16/08 12:54 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
On my buddies 69 RR. Were wondering if anybody has any pictures or diagrams for the factory tach dizzy's.
Moparlee
Re: factory tach disturbutors, how does the wire go? [Re: Robbins] #74476
06/16/08 02:20 PM
06/16/08 02:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The tach doesn't have anything to do with the distributer unless it's cable driven. You need the tach wire attached to the negative coil post.
Re: factory tach disturbutors, how does the wire go? [Re: stumpy] #74477
06/16/08 02:22 PM
06/16/08 02:22 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Oh....so what's the two wires for on the vacuum advance for then? Thanks.
Moparlee
Re: factory tach disturbutors, how does the wire go? [Re: Robbins] #74478
06/16/08 02:34 PM
06/16/08 02:34 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
not a factory set up
Re: factory tach disturbutors, how does the wire go? [Re: 05dakota] #74479
06/16/08 02:38 PM
06/16/08 02:38 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
We've(between my buddy and I) got an RB dizzy and a B dizzy that are both points and his 70 Challenger had it also. There are big honking blocks between the vacuum advance and the dizzy. These aren't factory?
Moparlee
Re: factory tach disturbutors, how does the wire go? [Re: Robbins] #74480
06/16/08 03:00 PM
06/16/08 03:00 PM
dogdays Offline
dogdays  Offline
DO you have a picture????
I'm having a hard time picturing this.
R.
Re: factory tach disturbutors, how does the wire go? [Re: dogdays] #74481
06/16/08 06:35 PM
06/16/08 06:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Lean burn?
Re: factory tach disturbutors, how does the wire go? [Re: Robbins] #74482
06/16/08 07:01 PM
06/16/08 07:01 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Sounds like the wire that goes to the dizzy for the NOX thing ?
Re: factory tach disturbutors, how does the wire go? [Re: OzHemi] #74483
06/16/08 08:36 PM
06/16/08 08:36 PM
Some '70 engines had a distributor retard solenoid. It connected to a "run" ignition source, and the second wire hooked to a switch contact on the carb. When the carb was at "curb idle" (warmed up) the switch on the carb would activate the solenoid and retard the timing at idle--for emission control.
Re: factory tach disturbutors, how does the wire go? #74484
06/17/08 07:10 AM
06/17/08 07:10 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Now this is making sense. We just assumed that it was for the tach, but the more I thought about it why would the tach be attached to the vacuum pod/advance.
Ya, I was just telling him this morning that we need to get a picture of them and post it. I'm trying to search the net for a picture now, but........
Moparlee
Re: factory tach disturbutors, how does the wire go? [Re: Robbins] #74485
06/17/08 08:56 AM
06/17/08 08:56 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
It's a little hard to see, but you can see a wire going to this one.
Moparlee
Re: factory tach disturbutors, how does the wire go? [Re: Robbins] #74486
06/17/08 09:41 AM
06/17/08 09:41 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Sounds like you have one of these little jewels?
Re: factory tach disturbutors, how does the wire go? [Re: ScottSmith_Harms] #74487
06/17/08 09:43 AM
06/17/08 09:43 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
So is the emission thing above is what them are for?
Moparlee
Re: factory tach disturbutors, how does the wire go? [Re: Robbins] #74488
06/17/08 10:26 AM
06/17/08 10:26 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Nobody runs these or got more pictures or diagrams. How about pictures of the switch on the carb?
Moparlee
Re: factory tach disturbutors, how does the wire go? [Re: Robbins] #74489
06/17/08 11:09 AM
06/17/08 11:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thats not correct on any 69 RR i have ever seen .
Re: factory tach disturbutors, how does the wire go? [Re: JohnRR] #74490
06/17/08 11:44 AM
06/17/08 11:44 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Nope, first started showing up on a few 1970 big block applications and continued on most 71 and later big block applications.
Re: factory tach disturbutors, how does the wire go? [Re: ScottSmith_Harms] #74491
06/17/08 11:46 AM
06/17/08 11:46 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Ok, I'm just trying to get all the information I can to give to him. Thanks guys.
Moparlee
Re: factory tach disturbutors, how does the wire go? [Re: Robbins] #74492
06/18/08 09:12 AM
06/18/08 09:12 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
HERE IS A SCAN FOR THE 1971 MODEL YEAR!!
JOHN MAC
Re: factory tach disturbutors, how does the wire go? [Re: 71_deputy] #74493
06/18/08 09:19 AM
06/18/08 09:19 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Thank you.
Moparlee
