factory tach disturbutors, how does the wire go?
#74475
06/16/08 12:54 PM
06/16/08 12:54 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
On my buddies 69 RR. Were wondering if anybody has any pictures or diagrams for the factory tach dizzy's.
Moparlee
Re: factory tach disturbutors, how does the wire go?
[Re: stumpy]
#74477
06/16/08 02:22 PM
06/16/08 02:22 PM
Robbins
Joplin, MO USA
Oh....so what's the two wires for on the vacuum advance for then? Thanks.
Moparlee
[Re: Robbins]
#74478
06/16/08 02:34 PM
06/16/08 02:34 PM
Posts: 17,861 albany ny
05dakota
albany ny
[Re: OzHemi]
#74483
06/16/08 08:36 PM
06/16/08 08:36 PM
Some '70 engines had a distributor retard solenoid. It connected to a "run" ignition source, and the second wire hooked to a switch contact on the carb. When the carb was at "curb idle" (warmed up) the switch on the carb would activate the solenoid and retard the timing at idle--for emission control.
[Re: Robbins]
#74485
06/17/08 08:56 AM
06/17/08 08:56 AM
Robbins
Joplin, MO USA
It's a little hard to see, but you can see a wire going to this one.
Moparlee
[Re: Robbins]
#74488
06/17/08 10:26 AM
06/17/08 10:26 AM
Robbins
Joplin, MO USA
Nobody runs these or got more pictures or diagrams. How about pictures of the switch on the carb?
Moparlee
[Re: Robbins]
#74489
06/17/08 11:09 AM
06/17/08 11:09 AM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
thats not correct on any 69 RR i have ever seen .
[Re: JohnRR]
#74490
06/17/08 11:44 AM
06/17/08 11:44 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Nope, first started showing up on a few 1970 big block applications and continued on most 71 and later big block applications.
[Re: ScottSmith_Harms]
#74491
06/17/08 11:46 AM
06/17/08 11:46 AM
Robbins
Joplin, MO USA
Ok, I'm just trying to get all the information I can to give to him. Thanks guys.
Moparlee
