Rounded plug - any tricks of the trade?
#744122
07/09/10 02:37 PM
07/09/10 02:37 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Trying to remove the plug as show in the pic. It's the one at the rear or the block usually used for oil pressure sending units. Mine's stuck and I rounded the square head. Can't get in there with vise grips. Any suggestions?
Re: Rounded plug - any tricks of the trade?
[Re: Commando1]
#744126
07/09/10 04:44 PM
07/09/10 04:44 PM
Commando1
Actually, I know about all the conventional methods. I'm an expert at removing these when the block is out of the car (See: Ask me how I know... ) I was just wondering if anyone had a tip when it's almost inaccesable as the one in this case. Doubt I can get in there to weld something to it, and, ditto for an E-Z Out.
[Re: RacerGofKGB]
#744127
07/09/10 07:56 PM
07/09/10 07:56 PM
Posts: 182 Pennsylvania
cantspel
Pennsylvania
You have any damaged bolt removers? Sorta like a socket but with reverse angled cutting teeth on the inside. They work great for removing bolts with rounded off heads.
These work great. http://www.craftsman.com/shc/s/p_10155_1...eyword=bolt+off
I have the snap on version of that set and it works great. If you can see it, you should be able to sneak in there with an extension or even a swivel
