Rounded plug - any tricks of the trade? #744122
07/09/10 02:37 PM
07/09/10 02:37 PM
South-Central (Sebring), FL
Commando1 Offline OP
Trying to remove the plug as show in the pic.
It's the one at the rear or the block usually used for oil pressure sending units.
Mine's stuck and I rounded the square head.
Can't get in there with vise grips.
Any suggestions?
Re: Rounded plug - any tricks of the trade? [Re: Commando1] #744123
07/09/10 02:42 PM
07/09/10 02:42 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You have any damaged bolt removers? Sorta like a socket but with reverse angled cutting teeth on the inside. They work great for removing bolts with rounded off heads.
Re: Rounded plug - any tricks of the trade? [Re: Commando1] #744124
07/09/10 02:42 PM
07/09/10 02:42 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
weld nut over it, try monster visegrips straight up, close then with channel locks for more grip,then twist with channel locks
MOPAR OR NO CAR
Re: Rounded plug - any tricks of the trade? [Re: DaytonaTurbo] #744125
07/09/10 02:57 PM
07/09/10 02:57 PM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
These work great.
http://www.craftsman.com/shc/s/p_10155_1...eyword=bolt+off
Re: Rounded plug - any tricks of the trade? [Re: Commando1] #744126
07/09/10 04:44 PM
07/09/10 04:44 PM
Actually, I know about all the conventional methods. I'm an expert at removing these when the block is out of the car (See: Ask me how I know... )
I was just wondering if anyone had a tip when it's almost inaccesable as the one in this case.
Doubt I can get in there to weld something to it, and, ditto for an E-Z Out.
Re: Rounded plug - any tricks of the trade? [Re: RacerGofKGB] #744127
07/09/10 07:56 PM
07/09/10 07:56 PM
Pennsylvania
cantspel Offline
cantspel  Offline
Pennsylvania
These work great.
I have the snap on version of that set and it works great. If you can see it, you should be able to sneak in there with an extension or even a swivel
Re: Rounded plug - any tricks of the trade? [Re: Commando1] #744128
07/09/10 08:22 PM
07/09/10 08:22 PM
hemigod426 Offline
hemigod426  Offline
looks like tons of room like its in a truck? tap on nut that stripped part fits inside tight and flush, put mig mound on top to fuse both, unthread with socket and extension, to it all the time on lot car cebies with rotted/shread off bolts
MOPAR OR NO CAR
Re: Rounded plug - any tricks of the trade? [Re: hemigod426] #744129
07/09/10 09:35 PM
07/09/10 09:35 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Good ideas so far, either welding a nut on it or using a left-handed thread nut and threading it on, would be my approach.
Re: Rounded plug - any tricks of the trade? [Re: topside] #744130
07/10/10 01:34 AM
07/10/10 01:34 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
leave it alone and pull the sender switch out , use a T fitting and attach whatever you were going to do there.
Re: Rounded plug - any tricks of the trade? [Re: RacerGofKGB] #744131
07/10/10 07:15 AM
07/10/10 07:15 AM
These work great.
Hmmm..
Where have these been all my life??
Had everything else failed, that was step 2.
Re: Rounded plug - any tricks of the trade? [Re: sthemi] #744132
07/10/10 09:24 AM
07/10/10 09:24 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I think this is the best advice given your situation.
If you do decide you need it out. My second vote goes to welding something on there. It's a no turning back option but I've had great luck with this method. Easy outs and reverse drills are often at a disadvantage because the offending bolt, nut or plug is stuck for a reason. IT'S FROZEN TO THE THREADS, not coming out easy.
Welding heats it's up red hot and I'm confident that also helps the removal.
