hurst shifter questions #744042
07/09/10 01:28 PM
07/09/10 01:28 PM
jersey shore
flypaper Offline OP
I hate Texas
flypaper  Offline OP
I hate Texas
jersey shore
does anyone know the application
of this shifter and rods?
it has the numbers 3830 09 on the reverse rod..
also i need a 71 bench shifter set up
i have the bench rods,could i use them with this shifter?
Re: hurst shifter questions [Re: flypaper] #744043
07/09/10 04:29 PM
07/09/10 04:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Frank , that's a mopar shifter , you can use it where you want to as long as your handle is a bolt on ...
Re: hurst shifter questions [Re: flypaper] #744044
07/09/10 07:50 PM
07/09/10 07:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Look for a number stamped in the Reverse (longest) lever in the shifter.
Re: hurst shifter questions [Re: John_Kunkel] #744045
07/09/10 07:57 PM
07/09/10 07:57 PM
jersey shore
flypaper Offline OP
I hate Texas
flypaper  Offline OP
I hate Texas
jersey shore
3830 09
Re: hurst shifter questions [Re: flypaper] #744046
07/09/10 08:00 PM
07/09/10 08:00 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
There's another bench seat 71 B-Body thread going right now.
Maybe it might help both parties to look at both threads.
https://board.moparts.org/ubbthreads/show...e=0#Post6076254
Re: hurst shifter questions [Re: SNK-EYZ] #744047
07/09/10 09:21 PM
07/09/10 09:21 PM
jersey shore
flypaper Offline OP
I hate Texas
flypaper  Offline OP
I hate Texas
jersey shore
i saw that thread and didn't want to hijack it
i wanted to know what the app on the shifter i had was
since i didn't know and also could it be used in a 71 bbody bench set up?
i have the dogbone and a set of rods
i don't know if i need the specific shifter or
if i could use this one?
Re: hurst shifter questions [Re: flypaper] #744048
07/09/10 11:14 PM
07/09/10 11:14 PM
A Red State
A Red State
The shifter body that you have here should work, but those are the wrong rods (look like 68-70 B-Body maybe).
You'd need the dogbone and the correct rods, if you have them you should be good to go.
Re: hurst shifter questions [Re: flypaper] #744049
07/09/10 11:31 PM
07/09/10 11:31 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i just found this thread the only differance i see in your shifter compared to mine is you have a stop botl on the front and i done and my bolts that hold the shifter on go in from the other side
the #,s om my reverse rod/finger are 7180 and driver sideback of shifter body is #1220231m
is a hurst shifter
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: hurst shifter questions [Re: toplescuda] #744050
07/10/10 11:20 PM
07/10/10 11:20 PM
jersey shore
flypaper Offline OP
I hate Texas
flypaper  Offline OP
I hate Texas
jersey shore
after further review
the answer is absolutly no..
the shifter is different
i bought the correct one brandy new from brewers today
