Which Master cylinder to use? #743258
07/08/10 12:58 AM
07/08/10 12:58 AM
Nampa, ID
None2Slow Offline OP
Nampa, ID
I just purchased the Wilwood 9" brake kit from Summit (Couldn't pass it up as it was only $400 new). Now the question is, which master cylinder to use? I currently have the single pot m/c that needs replaced anyways. Looking for ideas from you smart people and any tips on hoses, prop valves and any other advice you may have.
Re: Which Master cylinder to use? [Re: None2Slow] #743259
07/08/10 01:09 AM
07/08/10 01:09 AM
Asheboro NC
mopowertim Offline
super gas
mopowertim  Offline
super gas
Asheboro NC
My first guess would be the new style M/C that Rick Ereneburgh sells here on Moparts-he has the 4 to 2 bolt adapters as well. I think he also sells or reccomends the adjustable proportioning valve as well.
If you can't outrun it-Outlaw it! The King
Re: Which Master cylinder to use? [Re: mopowertim] #743260
07/08/10 01:16 AM
07/08/10 01:16 AM
Nampa, ID
Nampa, ID
I should add that Im using a Ford 8" rearend. Not sure if it has either 9" ar 10" drums. Just thought I would add this info.
Re: Which Master cylinder to use? [Re: None2Slow] #743261
07/09/10 12:55 AM
07/09/10 12:55 AM
Nampa, ID
Nampa, ID
any other ideas?
Re: Which Master cylinder to use? [Re: None2Slow] #743262
07/09/10 09:29 AM
07/09/10 09:29 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I bought a master cylinder from Cass at DR Diff and and am quite pleased. You will meed new lines since the size at the cylinder is different. I have 73 Duster front disks.
Re: Which Master cylinder to use? [Re: babarracuda] #743263
07/09/10 12:02 PM
07/09/10 12:02 PM
MI
marklock Offline
I tried too hard for a custom title
marklock  Offline
MI
I agree give Dr. Diff a call, he can help you out. I picked up a M/C and other related parts and am nothing but pleased with the parts and prices.
Re: Which Master cylinder to use? [Re: marklock] #743264
07/09/10 07:19 PM
07/09/10 07:19 PM
Nampa, ID
Nampa, ID
Thanks guys. Its been 7 or so years sice it ran and now I got most parts to get running. Figured I would upgrade the brakes while the engine is out. I'll try to get some "in progress: pics and post them.
Re: Which Master cylinder to use? [Re: None2Slow] #743265
07/09/10 08:50 PM
07/09/10 08:50 PM
N. Syracuse, NY
'64 Belvedere Offline
N. Syracuse, NY
I am doing a similar switch on my '64 Belvedere and looked at Wilwood tandem M.C. I was also told that the 1" was for a stiffer pedal and 7/8" was for more of a street car. But they are alot of money. Now I am trying to find out if I can use a M.C. out of a '73 Dart or '79 Diplomat (same M.C.) a lot less money.
Re: Which Master cylinder to use? [Re: mopowertim] #743266
07/09/10 11:44 PM
07/09/10 11:44 PM
NY NY
3
340duster340 Offline
NY NY
i have this if you need it ... PM me if interested.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
