8 3/4 width questions? #742293
07/06/10 10:38 PM
07/06/10 10:38 PM
Illinois USA
justnuts40 Offline OP
Illinois USA
Could any one tell me if there is a chart or something that could tell me what the diffrent widths are for mopar factory 8 3/4 rear housings are. I put a rear out of a C body in my 37 truck street rod. Know that I'm getting to tires, rims, and mounted fenders the C body rear is to wide. I have a rear housing that is about 3 and 1/2 inches shorter, but I have no axels and I don't know what the shorter rear came out of? I would rather find something stock and just move the spring perches instead of having something custom made.
Hope to hear from some one soon?
Thanks, Tony
etony58@gmail.com
Re: 8 3/4 width questions? *DELETED* [Re: justnuts40] #742294
07/06/10 10:43 PM
07/06/10 10:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Post deleted by stumpy
Re: 8 3/4 width questions? [Re: justnuts40] #742295
07/06/10 10:49 PM
07/06/10 10:49 PM
Under My Car
Mopar_Country Offline
Under My Car
A-body, 65-72 55.6 43.0
4" lug bolt circle,
offered in heavy duty apps.
B-body, 62-70 59.2 44.0
B-body, 71-72 62.0 47.3
B-body, 71-72 63.4 47.3
station wagon
C-body, 64-72 63.4 47.3
D-body, 64-72 63.4 47.3
E-body, 70-74 60.7 46.0
First dimension is flange to flange, second is perches cntr to cntr
Re: 8 3/4 width questions? [Re: stumpy] #742296
07/06/10 10:58 PM
07/06/10 10:58 PM
Poplar Bluff, Missouri
S&J Butler Offline
S&J Butler  Offline
Re: 8 3/4 width questions? [Re: Mopar_Country] #742297
07/06/10 11:23 PM
07/06/10 11:23 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
4" lug bolt circle,
station wagon
Where ever you got that info, trash it, it's wrong!
Use the measurements in the tech forum with the axle lengths, that is correct. fy-chally posted the link.
Re: 8 3/4 width questions? [Re: RobX4406] #742298
07/06/10 11:41 PM
07/06/10 11:41 PM
Under My Car
Under My Car
These measurements I believe are axle flange to axle flange. I guess I should have been more specific. I just measured the B body rear I have on the floor and it was just shy of 60 inches from where the drum contacts the axle flange. I guess if you subtract the distance from the axle flange to the housing flange the other chart is correct as well.
Re: 8 3/4 width questions? [Re: Mopar_Country] #742299
07/07/10 01:56 AM
07/07/10 01:56 AM
RobX4406 Offline
RobX4406  Offline
IT'S WRONG!!!
PERIOD
62-70 B's ARE NOT the same width.
A's ARE NOT that length, no way, no how. Cut one that length and put stock axles in. You'll be MIGHTY unhappy with the results. They are 52 5/8" flange to flange, 57 1/8" wheel mount to mount. At least the perch width is correct in that listing for A's.
The linked listing that FY-Chall posted has the CORRECT lengths.
