Time For A Change
#741598
07/06/10 11:17 AM
07/06/10 11:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I was going to pull my W-9 today to find a oil leak at the back of the engine.... well I decided to put my back up W-2 back in... its been a few years since I fired it but it all looks good and cranks over fine so I'll put it back in and maybe pull the W-9 down to give it a once over and see IF I can find some more power in it
Re: Time For A Change
[Re: MR_P_BODY]
#741599
07/06/10 11:27 AM
07/06/10 11:27 AM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
If there is some more to be found I am sure you will find it!!
Good to have a reliable back up engine on hand! Good luck with the swap. Don't forget to turn up the AC in the new shop, its AFRICA hot out there today!!
[Re: 440Jim]
#741602
07/06/10 12:58 PM
07/06/10 12:58 PM
MR_P_BODY
What CID is the W-2 engine? What do you think the car will run with that engine?
Jim, its a 396ci and the last time in it ran 9.56 but that was with gas... I'm going to run it on E-85 this time
[Re: cbarracuda]
#741607
07/06/10 03:57 PM
07/06/10 03:57 PM
MR_P_BODY
what is the weight of your car ready to race?
2410 race weight... it could use a bigger roller but it is what it is
Ted, I'm done for the day... had to find a few things before I could do anything... I'll start the swap in the morning when its cooler
[Re: HEMIDARTS]
#741610
07/06/10 06:38 PM
07/06/10 06:38 PM
MR_P_BODY
sweet! have fun, and take your time.
It got HOT here today 93 and tomorrow is going to be hotter with more humidity... I'll work in the morning then I will go to the welding shop... I ordered up some new toys so I will pick them up tomorrow
[Re: MR_P_BODY]
#741612
07/06/10 07:47 PM
07/06/10 07:47 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
These work wonders....have two fans in the shop...really takes the curse off the heat
Rickster
[Re: rickstershemi]
#741613
07/06/10 07:55 PM
07/06/10 07:55 PM
MR_P_BODY
Rickster
I have a smaller one of those and it works but its sorta noisey and I have a hard time listening to the stereo... tomorrow I will turn on my oscillating fan... if it gets to hot... I'll quit
[Re: MR_P_BODY]
#741614
07/06/10 08:19 PM
07/06/10 08:19 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
sounds like a good idea! It hit 94 yesterday here, and it was 95 today when i went to work. Keep some water on hand if you can, or go in the air and relax and drink, then go back out. That is what i do.
[Re: HEMIDARTS]
#741615
07/06/10 08:30 PM
07/06/10 08:30 PM
MR_P_BODY
That is what i do.
Funny thing... I dont drink water... havent in YEARS but I do drink diet Vernors alot... I will come in the house if I get hot... I'm not in a rush, I have plenty of time
[Re: MR_P_BODY]
#741617
07/06/10 09:36 PM
07/06/10 09:36 PM
Posts: 16,931 NC
440Jim
NC
That is plenty fast. Not a big deal, IMO.
