72 Road Runner power trunk #74127
06/15/08 05:55 PM
06/15/08 05:55 PM
North America
2002bluert Offline OP
North America
Anyone know where the power trunk release button is suppose to be and what it looks like on a 72 Road Runner. Thanks
Re: 72 Road Runner power trunk [Re: 2002bluert] #74128
06/15/08 07:11 PM
06/15/08 07:11 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
In general,if it has a power trunk release it would be in the glove box...Some early year vehicles{69-70} had a vacuum operated unit then in 71-up they were electric...You can't miss the early electric units...It's huge almost like a 3 speed wiper motor...
Re: 72 Road Runner power trunk [Re: 2002bluert] #74129
06/15/08 07:28 PM
06/15/08 07:28 PM
In the glove box. on the top, left of center. In 72 the PDCY cars used the vacuum style still, but the RW cars were electric. I cannot find a latch right now, but it had the solenoid attached. (pretty sure it is the same stuff as Cordoba Magnum)
Re: 72 Road Runner power trunk [Re: 2002bluert] #74130
06/15/08 09:36 PM
06/15/08 09:36 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I had a 71 Polara that had the vacuum trunk release, so who knows when it changed to electric.
Re: 72 Road Runner power trunk [Re: 2002bluert] #74131
06/15/08 09:51 PM
06/15/08 09:51 PM
Alabama
BigMoneyLewis Offline
Alabama
I heard alot of Canadian spec ,R code windsor built cars are coded for inside trunk release ,
but never installed . They are just coded for it.
I don't know , but I have heard that rumor for years.
Greg
Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios
We can restore YOUR radio usually in less than 7 days
Visit our NEW website..
http://www.wardsclassiccarradiorepair.com
gregward@mchsi.com
phone 256-852-0955
gregward@mchsi.com phone 256-852-0955
Re: 72 Road Runner power trunk [Re: RV2] #74132
06/15/08 10:04 PM
06/15/08 10:04 PM
my old 69 charger, electric.
Re: 72 Road Runner power trunk #74133
06/15/08 11:24 PM
06/15/08 11:24 PM
North America
North America
Thanks guys. I just bought this car the fender tag is coded for a power trunk. but there is no button in the glove box but there is one in the console not sure if its right. The power release is in the trunk.
Re: 72 Road Runner power trunk [Re: 2002bluert] #74134
06/15/08 11:26 PM
06/15/08 11:26 PM
North America
North America
Inside trunk
Re: 72 Road Runner power trunk [Re: 2002bluert] #74135
06/15/08 11:29 PM
06/15/08 11:29 PM
IA. ,USA
dodgeboychris Offline
IA. ,USA
Had a '73 Charger that had the electric trunk release (red button, I think) on the steering column. only reason I found it was i was working up under the dash and saw it, started pushing it and finialy figured out the noise was comming from the trunk. Think a buddys dads '73 Chrysler Newport was on the steering column too.
Re: 72 Road Runner power trunk [Re: 2002bluert] #74136
06/15/08 11:30 PM
06/15/08 11:30 PM
North America
North America
Inside console
Re: 72 Road Runner power trunk [Re: 2002bluert] #74137
06/15/08 11:33 PM
06/15/08 11:33 PM
North America
North America
Close up of button. Nothings wired up so not sure hows it suppose to be. Thanks again.
Re: 72 Road Runner power trunk [Re: 2002bluert] #74138
06/15/08 11:56 PM
06/15/08 11:56 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
There should be two wires which connect to the switch. One is hot power to the switch, and the other sends hot power to the trunk release when the button is depressed.
That does look like a factory switch in the console to me, just without the bezel as shown above.
Re: 72 Road Runner power trunk [Re: In_The_Pink] #74139
06/16/08 12:55 AM
06/16/08 12:55 AM
I agree, it should be white on the back with 2 blades. That retainer looks stock, and your glove liner has no hole...interesting. What is the part # (s) on the latch?
Re: 72 Road Runner power trunk #74140
06/16/08 01:13 AM
06/16/08 01:13 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
this is coming pretty much interesting!!! when I made same question to add for my 74 no one got me the RIGHT answer so I ended making this:
http://www.dodgecharger.com/forum/index.php?action=dlattach;topic=7603.0;id=12675;image
http://www.dodgecharger.com/forum/index.php?action=dlattach;topic=7603.0;id=12677;image
somebody told me was in that way though!
will be great to see an original setup... Is the latch system showed on this thread the original one ? My 74 Mopar parts catalog shows a GIANT unit ( as stated by screamindriver ). Of course I know the unit I got is from a later car, but shows pretty much similar with the one showed here.
Please keep the good info coming
Re: 72 Road Runner power trunk #74141
06/16/08 01:26 AM
06/16/08 01:26 AM
North America
North America
On the left hand side of the latch it says.
LECTRON
TROY MICH
PAT. NO. 3857001
And one the right hand side it says
3796 466
60043
Re: 72 Road Runner power trunk [Re: BigMoneyLewis] #74142
06/16/08 02:02 AM
06/16/08 02:02 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
f82 code is for inside trunk release not f81
V7W END
o M31 M41 N42 N96 R26 o
G33 J45 J52 L31 M21 M25
V1W U 26 B51 C55 F81
GB5 P6B5 GB7 xxx xxxxxx
E86 D21 RS23 U1R 146327 the f81 on tag
Re: 72 Road Runner power trunk [Re: 440beep] #74143
06/16/08 02:16 AM
06/16/08 02:16 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
F11 50 Amp Alternator
F13 60 Amp Alternator
F15 65 Amp Alternator
F17 Radio Supressor Package
F22 Battery 46 Amp Hour (Series 24 w/Green Caps)
F23 Battery 59 Amp Hour (Series 24 w/Yellow Caps)
F25 Battery 70 Amp Hour (Series 27 w/Red Caps)
F56 Antifreeze Tested -35º F
F82 Remote Control Deck Lid
F95 Certified Speedometer
F96 Oil Pressure Gauge
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
