Fluid still spitting out of rear vent??????
#740939
07/05/10 03:19 PM
07/05/10 03:19 PM
Posts: 294 Minnesota
RockChip
Minnesota
So i took the Coronet to the 1/8 mile track this weekend and after my second pass i had fluid spit out all over the top of the tranny again. So I cleened the mess up and drained fluid out till it was just above the add mark, and yes it was Damn hot. Then i made another pass and everything was fine, no fluid spitting out of the vent, tranny worked fine. After a cool down when they preped the track I made another pass and it slipped bad going into 3rd. ((low fluid lever probably caused this)) I have already plugged the park feed hole. I have run out of ideas Im seriously thinking of tossing the 727 for a glide, am I at the limit of the 727?
Re: Fluid still spitting out of rear vent??????
[Re: RockChip]
#740944
07/05/10 07:54 PM
07/05/10 07:54 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Yes I am runnin a deep pan.
I was thinking about the catch can idea.
The tranny seemes to work fine when it spits fluid but it shure is a pain
The catch can will solve your problems but do it right. Trans fluid is real flammable. Use good line/fittings and keep it as far as possible from any major heat source.
[Re: BobR]
#740945
07/05/10 10:22 PM
07/05/10 10:22 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
I had fluid come out of mine 2 weeks ago 1st time . Now I'm ??? the locking dipstick ,I went to drain the fluid and it gurgled out till i pulled the locking dipstick .Some of us feel its needs to breath like the old stick fitted loose .So we drilled a small hole below lock .Haven't tried it yet . DR
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: RockChip]
#740949
07/06/10 07:40 PM
07/06/10 07:40 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Yes i have sealing rings in the support, and i plugged the park feed hole.
Its not a roller support.
I have my vent in the tail housing next to the top left mount bolt area with a 90 and a 6" pice of steel tubing pointing forward towards front of car.
Is thare a possibility i had the tranny over full?
Yes,I would run it till it quits or put a overflow catch can with a vent and drain plug.
[Re: 440Jim]
#740950
07/06/10 09:31 PM
07/06/10 09:31 PM
Posts: 672 Keysville, VA
drag440
mopar addict
mopar addict
Keysville, VA
Where is your vent relocated to? What kind of vent do you have installed (plastic check type, etc) This pic shows where I put mine and it has never spit a drop. This location is well protected from fluid splash.
My new trans is blowing fluid out of the vent also. I have always put my vent in the case like in Jims pic and never had this problem. On this trans I put a Turbo Action roller rear support in it and for some reason put my vent in the top, front of my tail housing. I did plug my park hole and I did leave one ring out. When I put my rear shaft in it was hard to turn my shaft and I had a hard time getting my rear housing to go down. I think the bearing is in off center. I wish I had of thrown it in the trash. I have a hose that goes up with the dipstick with a plastic vent in it.
[Re: 440Jim]
#740952
07/08/10 11:27 AM
07/08/10 11:27 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
My vent is drilled in the same place, but I also drilled a small hole through the lower rib, just in case fluid gets up there it can drain out. I'm using the 1/8" NPT vent for a turbo400? that has a plastic tube pushed into the fitting. It comes close to the stock trans tunnel, but seems to work. I like the idea of a 90-degree fitting connected to a hard line back to the filler tube or catch can.
