Fluid still spitting out of rear vent?????? #740939
07/05/10 03:19 PM
07/05/10 03:19 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
So i took the Coronet to the 1/8 mile track this weekend and after my second pass i had fluid spit out all over the top of the tranny again.
So I cleened the mess up and drained fluid out till it was just above the add mark, and yes it was Damn hot.
Then i made another pass and everything was fine, no fluid spitting out of the vent, tranny worked fine.
After a cool down when they preped the track I made another pass and it slipped bad going into 3rd. ((low fluid lever probably caused this))
I have already plugged the park feed hole.
I have run out of ideas
Im seriously thinking of tossing the 727 for a glide, am I at the limit of the 727?
Re: Fluid still spitting out of rear vent?????? [Re: RockChip] #740940
07/05/10 04:38 PM
07/05/10 04:38 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Put a barb fitting in and run a line up past the side of the tranny to a place higher than the waist of the transmission. Mine would do the same thing so I did that first making it above top of bell housing then just went back to a pump housing vent as I foot brake mostly now so no hole in front drum anymore!
Re: Fluid still spitting out of rear vent?????? [Re: RockChip] #740941
07/05/10 04:56 PM
07/05/10 04:56 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Many with fast cars use a catch can. Take the vent out and get a vented catch can mounted under the car and run some appropriate line from the fitting where the vent used to be to the can. Are you using a deep pan? If so you should not have to run excess fluid in the system.
Re: Fluid still spitting out of rear vent?????? [Re: BobR] #740942
07/05/10 05:26 PM
07/05/10 05:26 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Yes I am runnin a deep pan.
I was thinking about the catch can idea.
The tranny seemes to work fine when it spits fluid but it shure is a pain
Re: Fluid still spitting out of rear vent?????? [Re: RockChip] #740943
07/05/10 05:43 PM
07/05/10 05:43 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
vented catch can
Re: Fluid still spitting out of rear vent?????? [Re: RockChip] #740944
07/05/10 07:54 PM
07/05/10 07:54 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The catch can will solve your problems but do it right. Trans fluid is real flammable. Use good line/fittings and keep it as far as possible from any major heat source.
Re: Fluid still spitting out of rear vent?????? [Re: BobR] #740945
07/05/10 10:22 PM
07/05/10 10:22 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
I had fluid come out of mine 2 weeks ago 1st time .
Now I'm ??? the locking dipstick ,I went to drain the fluid and it gurgled out till i pulled the locking dipstick .Some of us feel its needs to breath like the old stick fitted loose .So we drilled a small hole below lock .Haven't tried it yet .
DR
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Fluid still spitting out of rear vent?????? [Re: RockChip] #740946
07/06/10 01:05 PM
07/06/10 01:05 PM
NC
440Jim Offline
440Jim  Offline
NC
Where is your vent relocated to?
What kind of vent do you have installed (plastic check type, etc)
This pic shows where I put mine and it has never spit a drop. This location is well protected from fluid splash.
Re: Fluid still spitting out of rear vent?????? [Re: 440Jim] #740947
07/06/10 01:22 PM
07/06/10 01:22 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Are you still running sealing rings on the output shaft at the rear support?If your running a rollerized rear support you may want to discard one or both sealing rings.
Re: Fluid still spitting out of rear vent?????? [Re: B G Racing] #740948
07/06/10 07:34 PM
07/06/10 07:34 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Yes i have sealing rings in the support, and i plugged the park feed hole.
Its not a roller support.
I have my vent in the tail housing next to the top left mount bolt area with a 90 and a 6" pice of steel tubing pointing forward towards front of car.
Is thare a possibility i had the tranny over full?
Re: Fluid still spitting out of rear vent?????? [Re: RockChip] #740949
07/06/10 07:40 PM
07/06/10 07:40 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Yes,I would run it till it quits or put a overflow catch can with a vent and drain plug.
Re: Fluid still spitting out of rear vent?????? [Re: 440Jim] #740950
07/06/10 09:31 PM
07/06/10 09:31 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
My new trans is blowing fluid out of the vent also. I have always put my vent in the case like in Jims pic and never had this problem. On this trans I put a Turbo Action roller rear support in it and for some reason put my vent in the top, front of my tail housing. I did plug my park hole and I did leave one ring out. When I put my rear shaft in it was hard to turn my shaft and I had a hard time getting my rear housing to go down. I think the bearing is in off center. I wish I had of thrown it in the trash. I have a hose that goes up with the dipstick with a plastic vent in it.
Re: Fluid still spitting out of rear vent?????? [Re: drag440] #740951
07/08/10 11:24 AM
07/08/10 11:24 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I questioned this and fought it, with the hopes of stopping it in mine a few years ago. I finally put a radiator overflow catch can in with 2 additional holes drilled in it to release pressure. Just catch the fluid, check and drain the overflow periodically and race it.
Re: Fluid still spitting out of rear vent?????? [Re: 440Jim] #740952
07/08/10 11:27 AM
07/08/10 11:27 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My vent is drilled in the same place, but I also drilled a small hole through the lower rib, just in case fluid gets up there it can drain out. I'm using the 1/8" NPT vent for a turbo400? that has a plastic tube pushed into the fitting. It comes close to the stock trans tunnel, but seems to work. I like the idea of a 90-degree fitting connected to a hard line back to the filler tube or catch can.
