Re: new 383 Not Oiling!!!!
[Re: okie]
#740830
07/14/10 08:34 AM
07/14/10 08:34 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
All the rockers have holes in them so maybe they would work. Ronnie
Yes they have holes but what will happen is the oil would spray up on the valve cover and drip down on TOP of the shaft and the rocker, there is a reason the oil hole is UNDER the rocker , that's where the oil needs to be , not dripping on top of the shaft .
It's your decision, your motor and your money.
[Re: okie]
#740832
07/14/10 01:44 PM
07/14/10 01:44 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
If your willing to pull the cam, why don't you just replace the incorrectly installed cam bearing? (And not remove the head too) Quote:
I could pull the cam and the 1 head and drill out the bearing for that side and that is what I'm thinking about doing. That way I won't have to pull the motor which is what I don't want to do. Ronnie
[Re: Jwilli500]
#740834
07/14/10 02:52 PM
07/14/10 02:52 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
If your willing to pull the cam, why don't you just replace the incorrectly installed cam bearing? (And not remove the head too)Quote:
That might make sense.
[Re: Jwilli500]
#740836
07/14/10 03:23 PM
07/14/10 03:23 PM
JohnRR
Have you ever tried to replace a bearing from the top? It's going to be pretty hard to do it that way, doable but there is the risk of dropping the old bearing and/or the new one .
[Re: buildanother]
#740843
07/14/10 09:49 PM
07/14/10 09:49 PM
Posts: 1,200 UK
602heavy
UK
Think I've seen different patterns drilled on some mfgs.
This applies to all B/RB motors , obviously will deviate a few degrees depending on lobe sep , all the same it gets you pretty close , can sometimes be a pain trying to turn the motor over with a drill in the other hand.
[Re: okie]
#740844
07/15/10 11:31 AM
07/15/10 11:31 AM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Okie, I'd drop in and give you a hand on this but this weekend is kinda busy. I'm sure we'd be able to get oil to the other side without excessive hassle.
