Page 4 of 5 1 2 3 4 5
Re: new 383 Not Oiling!!!! [Re: 540challenger] #740825
07/14/10 07:53 AM
07/14/10 07:53 AM
florida/ Georgia
Tom Fox Offline
Tom Fox  Offline
florida/ Georgia
you might as well face the fact, you are going to have to pull the engine and replace the cam bearing. Tom
Re: new 383 Not Oiling!!!! [Re: Tom Fox] #740826
07/14/10 08:17 AM
07/14/10 08:17 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
All the rockers have holes in them so maybe they would work. Ronnie
Re: new 383 Not Oiling!!!! [Re: okie] #740827
07/14/10 08:19 AM
07/14/10 08:19 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
By the time you waste all this time on the internet, you could have had the motor out of the car and apart.
Re: new 383 Not Oiling!!!! [Re: okie] #740828
07/14/10 08:20 AM
07/14/10 08:20 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
I could pull the cam and the 1 head and drill out the bearing for that side and that is what I'm thinking about doing. That way I won't have to pull the motor which is what I don't want to do. Ronnie
Re: new 383 Not Oiling!!!! [Re: okie] #740829
07/14/10 08:31 AM
07/14/10 08:31 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Remember to clean all the fillings out if you drill it. It could be fun with the engine still in the car. If you have your ducks in a row you can have that engine out in an hour +/-.
Re: new 383 Not Oiling!!!! [Re: okie] #740830
07/14/10 08:34 AM
07/14/10 08:34 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Yes they have holes but what will happen is the oil would spray up on the valve cover and drip down on TOP of the shaft and the rocker, there is a reason the oil hole is UNDER the rocker , that's where the oil needs to be , not dripping on top of the shaft .
It's your decision, your motor and your money.
Re: new 383 Not Oiling!!!! [Re: JohnRR] #740831
07/14/10 01:04 PM
07/14/10 01:04 PM
Upper Midwest
Upper Midwest
Do it right (correctly) now or pay later.
Re: new 383 Not Oiling!!!! [Re: okie] #740832
07/14/10 01:44 PM
07/14/10 01:44 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
If your willing to pull the cam, why don't you just replace the incorrectly installed cam bearing? (And not remove the head too)
Re: new 383 Not Oiling!!!! [Re: JohnRR] #740833
07/14/10 02:24 PM
07/14/10 02:24 PM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
This space available for rent
Re: new 383 Not Oiling!!!! [Re: Jwilli500] #740834
07/14/10 02:52 PM
07/14/10 02:52 PM
Upper Midwest
Upper Midwest
That might make sense.
Re: new 383 Not Oiling!!!! [Re: okie] #740835
07/14/10 03:10 PM
07/14/10 03:10 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Where in OK are you?
- Stu Harmon
Re: new 383 Not Oiling!!!! [Re: Jwilli500] #740836
07/14/10 03:23 PM
07/14/10 03:23 PM
Have you ever tried to replace a bearing from the top? It's going to be pretty hard to do it that way, doable but there is the risk of dropping the old bearing and/or the new one .
Re: new 383 Not Oiling!!!! [Re: JohnRR] #740837
07/14/10 04:47 PM
07/14/10 04:47 PM
UK
602heavy Offline
602heavy  Offline
UK
Turn motor over till #7 ex lifter is over the nose , this will line up cam & oil feed to drivers head , the same applies for #8 ex lobe oiling pas side head , this will let you know if oil holes in #4 cam bearing line up with oil feed in block , good luck.
Re: new 383 Not Oiling!!!! [Re: 602heavy] #740838
07/14/10 05:39 PM
07/14/10 05:39 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
OK I don't know what I'm going to do yet. I'm just getting over kidney surgery (cancer) and I really don't feel like tearing it down but I may have to. If I do tear it down I'm going to pull the head and drill it out instead of trying to replace the bearing. I just wanted to get the car done it has been a long time getting to this point. Thanks Everyone for the advice and help. Ronnie Feets I'm just across the river north of Dallas on 69 just past Choctaw Casino.. Thanks Ronnie
Re: new 383 Not Oiling!!!! [Re: okie] #740839
07/14/10 07:22 PM
07/14/10 07:22 PM
Delray beach, Florida
P
Performance Only Offline
P
what are you planning to do about all the metal filing that will inevitably get on the oil pump and destroy it. not to mention what will get thrown up on the cylinder walls to get trapped between the piston and wall. honestly, the best fix isn't going to be the easiest fix, but it's still the best one..
machine shop owner and engine builder
Re: new 383 Not Oiling!!!! [Re: Performance Only] #740840
07/14/10 07:25 PM
07/14/10 07:25 PM
Upper Midwest
Upper Midwest
Thanks for backing up my statement from above a few posts.
Re: new 383 Not Oiling!!!! [Re: 602heavy] #740841
07/14/10 09:11 PM
07/14/10 09:11 PM
I'm gonna copy this for sure
Re: new 383 Not Oiling!!!! [Re: RapidRobert] #740842
07/14/10 09:23 PM
07/14/10 09:23 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Think I've seen different patterns drilled on some mfgs.
Re: new 383 Not Oiling!!!! [Re: buildanother] #740843
07/14/10 09:49 PM
07/14/10 09:49 PM
UK
602heavy Offline
602heavy  Offline
UK
This applies to all B/RB motors , obviously will deviate a few degrees depending on lobe sep , all the same it gets you pretty close , can sometimes be a pain trying to turn the motor over with a drill in the other hand.
Re: new 383 Not Oiling!!!! [Re: okie] #740844
07/15/10 11:31 AM
07/15/10 11:31 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Okie, I'd drop in and give you a hand on this but this weekend is kinda busy. I'm sure we'd be able to get oil to the other side without excessive hassle.
- Stu Harmon
