Help, My 2000 ram is stalling #740473
07/04/10 06:56 PM
07/04/10 06:56 PM
Ridgeland, WI, 54763
Curt57 Offline OP
Curt57  Offline OP
My truck started stalling with out notice. When going down the road at speed. The dash goes dead. And the odometer read NO BUSS. I thought it was the Automatic shutdown relay. By switching it with another. It would start and run till it decieds to stall again. Usually 5 to 10 miles. But somtimes 1 mile. Help! I really need my truck
Curt
Re: Help, My 2000 ram is stalling [Re: Curt57] #740474
07/04/10 08:46 PM
07/04/10 08:46 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hello, Really need some more info. Does it act like it is running out of gas or just instantlly quits? Does the dash guages do any thing strange? I've seen alternators make the dash guages fluctuate wildly and cause the veh to die. Seen this many times in my shop. Check the charging system. Loosing the dash could be a ground issue. Hope this helps some! Jeff
Re: Help, My 2000 ram is stalling [Re: 1969RR] #740475
07/04/10 10:40 PM
07/04/10 10:40 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
what's your battery voltage? Weird stuff starts happening to electronics when the battery voltage drops too low (or bad ground).
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Help, My 2000 ram is stalling [Re: GO_Fish] #740476
07/04/10 11:32 PM
07/04/10 11:32 PM
Curt57 Offline OP
Curt57  Offline OP
All the gauges go flat. It acts just like some one shut the key off. Battery votage is where it belongs. THANKS Curt
Re: Help, My 2000 ram is stalling [Re: Curt57] #740477
07/05/10 12:39 AM
07/05/10 12:39 AM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
I had an igntion switch go bad kind of like that before, try and see if you can get it to do it by wiggling the key a little bit and see if you can get it to act up.
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: Help, My 2000 ram is stalling [Re: sreinheimer] #740478
07/05/10 09:43 AM
07/05/10 09:43 AM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
Have the battery tested also.Mopars do some strange stuff if the battery is going.Rocky
Chrysler Firepower
Re: Help, My 2000 ram is stalling [Re: therocks] #740479
07/05/10 02:22 PM
07/05/10 02:22 PM
Curt57 Offline OP
Curt57  Offline OP
It doesn't seem to be battery or key switch related. What about sensors.Crank, cam, pcm, or ?. Some times it goes to the piont that I think its fixed. Next it goes a mile. THANKS for any help. Curt
Re: Help, My 2000 ram is stalling [Re: Curt57] #740480
07/05/10 02:56 PM
07/05/10 02:56 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Curt, You're gonna have to get a flow chart and follow it. Don't guess and throw parts at it...too expensive. Could be as simple as a bad connector at any sensor, module etc...If you have access to a fax, I can download a chart and fax it to you. Take care, Jeff
Re: Help, My 2000 ram is stalling [Re: 1969RR] #740481
07/05/10 03:09 PM
07/05/10 03:09 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
What no buss means is that the cluster is not able to communicate with pcm. What is probably happening is that a 5 or 8 volt sensor has a intermittant short and the pcm is shutting down to protect the circuit. If you had a scan tool I bet that everytime it restarts the starts since clear is 0 key starts due to pcm reseting. Crank sensor is most common for this but again it could be any 5 or 8 volt sensor. Have also put in a few 02 sensors for this issue.
