Oil Pressure sending unit problem? #73998
06/15/08 11:56 AM
06/15/08 11:56 AM
SC
V194 Offline OP
V194  Offline OP
SC
Started up the car to cruise to a show yesterday and noticed the gauge (70 Cuda)was reading very low. The gauge fluctuated slowly between half reading and none. I hit the highway thinking that if its going to give way then its now or never. The gauge acted the same and there was no apparent ill effects on the car (No noise, smoke or otherwise) A mechanic at the show suggested it was the oil pressure sending unit and just replace that. I looked at the unit and found that I had replaced that piece during an underhood detail session with a new unit only about a year ago.
So is it the unit, oil pump or something in the gauge?
Re: Oil Pressure sending unit problem? [Re: V194] #73999
06/15/08 12:15 PM
06/15/08 12:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Check it with a mechanical gauge.Ive never trusted elec gauges>Too much to go wrong.That and just because the sender was new dosent mean its good.Ive heard that line too many times in turning wrenches for almost 30 years.It cant be bad its new.Yeah right.Seen too mant new parts that are bad.That and if the pressure checks good try a new sender they are cheap.Rocky
Chrysler Firepower
Re: Oil Pressure sending unit problem? [Re: therocks] #74000
06/15/08 12:22 PM
06/15/08 12:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you check the wire to be sure it's snug on the the sender. Those push ons loosen up over time.
Re: Oil Pressure sending unit problem? [Re: stumpy] #74001
06/15/08 01:51 PM
06/15/08 01:51 PM
And, of course, don't forget our old friend, "the corroded firewall connector."
There is VERY little current in this circuit, so if the firewall / bulkhead connector is corroded/dirty, that will break the gauge connection.
Re: Oil Pressure sending unit problem? *DELETED* #74002
06/15/08 02:26 PM
06/15/08 02:26 PM
BDW Offline
BDW  Offline
Post deleted by cnxt
Re: Oil Pressure sending unit problem? [Re: BDW] #74003
06/15/08 02:27 PM
06/15/08 02:27 PM
BDW Offline
BDW  Offline
I had exact same problem, it turned out to be the instrument panel voltage regulator. Wasn't able to supply enough current. All the other gauges worked fine, just the oil was flakey
