Re: Oil Pressure sending unit problem?
[Re: V194]
#73999
06/15/08 12:15 PM
06/15/08 12:15 PM
Posts: 21,063 Niles , Ohio
therocks
Niles , Ohio
Check it with a mechanical gauge.Ive never trusted elec gauges>Too much to go wrong.That and just because the sender was new dosent mean its good.Ive heard that line too many times in turning wrenches for almost 30 years.It cant be bad its new.Yeah right.Seen too mant new parts that are bad.That and if the pressure checks good try a new sender they are cheap.Rocky
Chrysler Firepower
[Re: stumpy]
#74001
06/15/08 01:51 PM
06/15/08 01:51 PM
And, of course, don't forget our old friend, "the corroded firewall connector."
There is VERY little current in this circuit, so if the firewall / bulkhead connector is corroded/dirty, that will break the gauge connection.
Re: Oil Pressure sending unit problem? *DELETED*
#74002
06/15/08 02:26 PM
06/15/08 02:26 PM
Posts: 4,703 Florida
BDW
[Re: BDW]
#74003
06/15/08 02:27 PM
06/15/08 02:27 PM
BDW
I had exact same problem, it turned out to be the instrument panel voltage regulator. Wasn't able to supply enough current. All the other gauges worked fine, just the oil was flakey
