tranny lines and firing up motor #739367
07/03/10 12:16 PM
07/03/10 12:16 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Quick question:
I'm getting ready to fire up the 440/727 that was placed in my '69 Charger 500 1 to 1.5 years ago. The motor/tranny that was installed came from a completely running/driving '69 New Yorker (IIRC). I've got the motor/ignition in a way I can fire up the motor. I'm going to install the radiator, but don't have tranny lines yet. Right now, there is a rubber line connecting the inlet/outlet on the tranny. Will it hurt the tranny if I fire up the motor for a couple of minutes?, no tranny engagement. It'll be a milestone in the car's project future.
Thanks in advance..
Troy
Houston Mopar Connection Club
Re: tranny lines and firing up motor [Re: hemi68charger] #739368
07/03/10 12:19 PM
07/03/10 12:19 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
No problem .. just make sure there is ATF in there
Re: tranny lines and firing up motor [Re: hemi68charger] #739369
07/03/10 12:25 PM
07/03/10 12:25 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
should be ok with no load on the output shaft.
Re: tranny lines and firing up motor [Re: hemi68charger] #739370
07/03/10 12:27 PM
07/03/10 12:27 PM
Locomotion Offline
Locomotion  Offline
Make sure the rubber line is secure on the ends so it doesn't blow off. Not sure if plain rubber fuel line hose will take the pressure itself because trans fluid pressure can be 100-150 psi.
Re: tranny lines and firing up motor [Re: Locomotion] #739371
07/03/10 02:36 PM
07/03/10 02:36 PM
okla.
O
okie Offline
okie  Offline
O
okla.
I didn't think the pump was pumping in park. Ronnie
Re: tranny lines and firing up motor [Re: okie] #739372
07/03/10 02:59 PM
07/03/10 02:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pump is pumping whenever the crankshaft is turning.
To run it for even a few minutes there should be sufficient fluid in the trans to allow the converter to fill and bring the fluid level near full. Do the running in Neutral, not Park.
Re: tranny lines and firing up motor [Re: John_Kunkel] #739373
07/03/10 04:35 PM
07/03/10 04:35 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
sorry to hijack the the thread but I have a somewhat related question.
I've got my new engine and trans in ready to run but am still waiting on the rear end. Would I be able to run this with out the rear end installed? I do have a driveshaft that I could use to plug the output shaft of the transmission but just want to make sure it would be ok to run in neutral as the other end of the driveshaft wouldn't be connected to anything.
Re: tranny lines and firing up motor [Re: chache876] #739374
07/03/10 05:57 PM
07/03/10 05:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you run it in Neutral with the driveshaft disconnected from the rearend the shaft will turn due to the "windmilling" effect in the transmission. If you could find a way to support the driveshaft and keep it from turning you'd be OK.
Re: tranny lines and firing up motor [Re: John_Kunkel] #739375
07/03/10 06:12 PM
07/03/10 06:12 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
If I were to use a tailshaft plug instead of installing the driveshaft would that work too?
Re: tranny lines and firing up motor [Re: Locomotion] #739376
07/04/10 10:06 AM
07/04/10 10:06 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
The cooler has 30 psi max. from the trans.
lube circuit.
Gas hose & screw clamps will work fine, see
it alot on a permanent basis on drivers.
