rear super stock springs #739313
07/03/10 10:07 AM
07/03/10 10:07 AM
Edgewater, Md
swinger73 Offline OP
Edgewater, Md
I recently installed super stock springs on the rear of my 73 Dart. I don't like the way it sits uneven what is the best way to fix this, crank up the left front torsion bar or put another right side spring on the left side? I like the ride height just not the fact that the right side sits higher.
Re: rear super stock springs [Re: swinger73] #739314
07/03/10 12:42 PM
07/03/10 12:42 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Either way works to level the car.
Re: rear super stock springs [Re: topside] #739315
07/03/10 08:26 PM
07/03/10 08:26 PM
Stockbridge, GA
7D9LRE Offline
7D9LRE  Offline
Stockbridge, GA
I don't want to high jack your post, just a quick question. Are the '65-'66 rear springs the same as length as later A-bodies?
Re: rear super stock springs [Re: 7D9LRE] #739316
07/03/10 08:40 PM
07/03/10 08:40 PM
Edgewater, Md
Edgewater, Md
The springs I bought say they will fit a 64-76 A-body so I would say yes.
Re: rear super stock springs [Re: swinger73] #739317
07/03/10 10:08 PM
07/03/10 10:08 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
You can also have a local spring shop take some arch out of the right spring or add some to the left.
I prefer the preloaded torsion bar on a drag car because plants the right tire harder.
Re: rear super stock springs [Re: swinger73] #739318
07/04/10 03:46 AM
07/04/10 03:46 AM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
Can you turn the right hanger upside down?
Re: rear super stock springs [Re: swinger73] #739319
07/04/10 04:45 AM
07/04/10 04:45 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
You can run either two left side springs or two right side springs. That's what I did. Works great, car sits even and looks level.
Re: rear super stock springs [Re: jbc426] #739320
07/04/10 09:02 AM
07/04/10 09:02 AM
Edgewater, Md
Edgewater, Md
Which did you use 2 lefts or 2 rights? I like the height of the right sides but am worried it will make the rear too stiff and cause it to bounce around a lot.
Re: rear super stock springs [Re: swinger73] #739321
07/04/10 09:36 AM
07/04/10 09:36 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Most SS springs are 120lbs/inch. Not that stiff. The 002/003 springs are 160lbs/inch. Still not real stiff. Some of the stock springs are over 200lbs/inch.
You do understand that if you use 2 the same that they will not work the way they were designed. The car may launch crooked. They are biased for a reason.
Re: rear super stock springs [Re: GomangoCuda] #739322
07/04/10 09:58 AM
07/04/10 09:58 AM
Edgewater, Md
Edgewater, Md
Yup I do know that however using the SS springs was most likely not the best idea I have ever had in the first place, as I am just building a street car not a strip car. I am just trying to correct my mistake for the least amount of money. I am concerned that if I crank up the left front to level the car it will have an adverse effect on how the car handles.
Re: rear super stock springs [Re: swinger73] #739323
07/04/10 10:29 AM
07/04/10 10:29 AM
Gateway to the West.
hemi_harvester Offline
Try just unbolting the stack and taking the bottom 1/2 spring out of the stack.
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: rear super stock springs [Re: hemi_harvester] #739324
07/04/10 07:45 PM
07/04/10 07:45 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I would like to part with my 65 coronet super stock springs, They were not the right choice for my application.
Re: rear super stock springs [Re: convx4] #739325
07/04/10 10:41 PM
07/04/10 10:41 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
At my shop we have done hundreds of those. The right rear does have more bias built in it. It is that way to control the twist from the torque . By using the torsion bars to level it is what you want to do so you can put into it the planed amount of bias the spring was designed for. There is not an issue in the handling of the car if aligned right afterwords.
JAKES AUTOMOTIVE
Re: rear super stock springs [Re: JAKE68] #739326
07/05/10 09:32 AM
07/05/10 09:32 AM
Edgewater, Md
Edgewater, Md
Thanks Jake I think you just saved me another hundred bucks, headed out to crank up the front.!!
