Re: best replacement carb for a thermo quad [Re: dartman366] #739254
07/03/10 11:36 PM
07/03/10 11:36 PM
OH
junkyardmaxie Offline
Happy Birthday junkyardmaxie  Offline
OH
Bill there was a guy posted a holley 750 vac secondary rebuilt for $125.00 also had another carb edelbrock, on same post. i think it was in race parts for sale, or mopar motors big blocks Bob
Re: best replacement carb for a thermo quad [Re: junkyardmaxie] #739255
07/03/10 11:46 PM
07/03/10 11:46 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
if its going back on your stock MH rebuild stock, but for performance get a bunch of # drill bits, bunch of jets, rods, sec jets, and start drilling on your lathe, no aftermarket help for jets or bigger seats, i got the one in the pic working good but the 750 holley carb with annular boosters was still better.
Re: best replacement carb for a thermo quad [Re: ademon] #739256
07/04/10 02:15 AM
07/04/10 02:15 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
why hasn't anybody suggested the Edelbrock? i keep one in my shed i fit up to cars that run like bags of ch!t, just to prove it's a carb fault. i bought a strip kit for mine but it just works so well as it came stock. they're almost a T/quad in their design & just like the T/quad, no gaskets below the fuel line.
Re: best replacement carb for a thermo quad [Re: rebel] #739257
07/04/10 07:17 AM
07/04/10 07:17 AM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
That's one that I was asking about also in my origional post also, a friend of mine put a Edelbrock on his 340 Cuda and love's it,,,took a little to get it tuned in, but once we hit the sweet spot then
Re: best replacement carb for a thermo quad [Re: dartman366] #739258
07/04/10 08:01 AM
07/04/10 08:01 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
If it sit's more than a week you have to prime the carb with gas to start it, no amount of pumping the accelerator give's it enough gas to start,, act's like the bowl's are completely dry,,,won't go into 4 barrel mode when pedal is slammed to the floor, run's on 2 barrel only,,,idle adjustment screw's have no effect on idle quality,,,and it is just a scuzzy, scurvey, nasty looking mess,,I just want to make sure all is good and ready to go with the best economy that I can get from this barge.
Doesn't sound like 'Thermoquad only' carb-problems to me. More just a neglect of maintainance
The "no-4bbl" mode sounds like a simple linkage adjustment could fix easily, or maybe the sec. airvalve spring is adjusted too tightly. Does the kickdown function OK?
Idle screws, perhaps the fuel passages are blocked with dirt or something, or there's a vacuum problem somewhere.
The 'empty' carb priming is something more cars have and can be fixed by installing a simple fuelpump near the fueltank.
Adding a thicker heat insulating spacer under the carb could help aswell.
If you decide you want another carb, I would personally go with an Edelbrock carb.
Re: best replacement carb for a thermo quad [Re: BigBlockMopar] #739259
07/04/10 11:57 AM
07/04/10 11:57 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Mega-DITTOS to SOME of what HermO said .....
'cept that Eddy carb ...
That is a stone-age carb compared to the TQ. You want FUEL ECON ? .... stick with the TQ.
Get an older FACTORY service manual .... good info and tips in there. PLUS ....go to Napa and get a set of brass floats. Those plastic floats(using the alky-blended fuels) ...are NOT the plan.
Re: best replacement carb for a thermo quad [Re: BigBlockMopar] #739260
07/04/10 01:12 PM
07/04/10 01:12 PM
murfreesboro, TN
Q
Qbird Offline
Qbird  Offline
Q
murfreesboro, TN
All of his symptoms, with the exception of no secondary operation, can be traced directly to leaking wells in the bottom of the float bowl. Break out the JB weld an it'll be fine.
Re: best replacement carb for a thermo quad [Re: dOoC] #739261
07/04/10 01:16 PM
07/04/10 01:16 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree, the only thing to replace a Thermoquad with is another Thermoquad. Unless you are going to a modern race carb (which is not going to typically offer the best driveability or fuel economy) it's pretty much impossible to beat a properly tuned Thermoquad for all around everything. I also agree, the Carter AVS/Edelbrock carb is a good/simple carb but really doesn't offer the "best" of anything, it's an average middle of the road design. Most people like them because they are very basic and easy to tune and setup.
Re: best replacement carb for a thermo quad [Re: ScottSmith_Harms] #739262
07/04/10 06:00 PM
07/04/10 06:00 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Thank's for all the good info guy's,,,look's like I am going to try an attempt at fixing this myself, soon as I get a couple of items fixed first because I will need to start it and move it around once those thing's are done then I will tackle the carb,,,what's the worse that can happen?
Re: best replacement carb for a thermo quad [Re: dOoC] #739263
07/04/10 06:26 PM
07/04/10 06:26 PM
The Netherlands
The Netherlands
Leaky fuel wells would make the engine run rich all the time, and would also cause hard starting everytime you turn off the engine, as some fuel continue to dribble into the manifold. Been there done that.
Of course they could still leak ofcourse, and it would be probably smart to carefully break 'm loose anyway and reglue them again with JB Weld.
Well, at least we still agree on THIS then I suppose...
Re: best replacement carb for a thermo quad [Re: BigBlockMopar] #739264
07/04/10 06:35 PM
07/04/10 06:35 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Any one ever heard of Southern Carb's and rc hobby in Jackson Mississippi?,,,looked up Thermoquad's on E-Bay and they came up as a supplier,,,98% posative feedback. seem's to be reasonable on their pricing for complete rebuild's.
Re: best replacement carb for a thermo quad [Re: dartman366] #739265
07/04/10 06:38 PM
07/04/10 06:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
How much do they want..........I did one years ago and heard it ended up on a bad ass record setting small block I`m just saying.... 1-760-241-1149
Re: best replacement carb for a thermo quad [Re: Thumperdart] #739266
07/04/10 06:48 PM
07/04/10 06:48 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
239.00 for the one listed, and a 6 month warranty.I have your # wrote down in my little book of important people to know.
Re: best replacement carb for a thermo quad [Re: dartman366] #739267
07/04/10 06:52 PM
07/04/10 06:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Is that a rebuild or exchange? I can definately beat that price..........And, I can get it back to ya in a couple of days. Oh, I`m not THAT important....
Re: best replacement carb for a thermo quad [Re: dartman366] #739268
07/04/10 07:00 PM
07/04/10 07:00 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
Hite rebuilders here in Columbus on Mckinley ave. ,great job have done several for me for my customers on the old church bus Dodge vans
Re: best replacement carb for a thermo quad [Re: Thumperdart] #739269
07/04/10 07:03 PM
07/04/10 07:03 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
That is a buy now.
Re: best replacement carb for a thermo quad [Re: dartman366] #739270
07/04/10 07:05 PM
07/04/10 07:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s about right I guess.......why buy when yours was working and just needs a freshen and of course a few TWEEKS........your call......good luck.
Re: best replacement carb for a thermo quad [Re: dartman366] #739271
08/02/10 08:16 PM
08/02/10 08:16 PM
AZ, USA
moon Offline
moon  Offline
AZ, USA
I have a question about the thermoquad for a 360. im looking to get one but i dont have the original and the person on the phone as if the bowl vent was in the front or rear. I dont which one i need or is better. can anyone help me??
Re: best replacement carb for a thermo quad [Re: moon] #739272
08/02/10 09:58 PM
08/02/10 09:58 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
might ask this question in the resto section, I am sure those guy's would know, sorry I cant help but here's a for ya any way....oh and by the way the rebuilt thermoquad appears to work great, hope to take her on a short road trip this weekend.
