Re: best replacement carb for a thermo quad
[Re: junkyardmaxie]
#739255
07/03/10 11:46 PM
07/03/10 11:46 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
if its going back on your stock MH rebuild stock, but for performance get a bunch of # drill bits, bunch of jets, rods, sec jets, and start drilling on your lathe, no aftermarket help for jets or bigger seats, i got the one in the pic working good but the 750 holley carb with annular boosters was still better.
[Re: rebel]
#739257
07/04/10 07:17 AM
07/04/10 07:17 AM
dartman366
Mt. Vernon, Ohio
why hasn't anybody suggested the Edelbrock? i keep one in my shed i fit up to cars that run like bags of ch!t, just to prove it's a carb fault. i bought a strip kit for mine but it just works so well as it came stock. they're almost a T/quad in their design & just like the T/quad, no gaskets below the fuel line.
That's one that I was asking about also in my origional post also, a friend of mine put a Edelbrock on his 340 Cuda and love's it,,,took a little to get it tuned in, but once we hit the sweet spot then
[Re: dartman366]
#739258
07/04/10 08:01 AM
07/04/10 08:01 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
If it sit's more than a week you have to prime the carb with gas to start it, no amount of pumping the accelerator give's it enough gas to start,, act's like the bowl's are completely dry,,,won't go into 4 barrel mode when pedal is slammed to the floor, run's on 2 barrel only,,,idle adjustment screw's have no effect on idle quality,,,and it is just a scuzzy, scurvey, nasty looking mess,,I just want to make sure all is good and ready to go with the best economy that I can get from this barge.
Doesn't sound like 'Thermoquad only' carb-problems to me. More just a neglect of maintainance The "no-4bbl" mode sounds like a simple linkage adjustment could fix easily, or maybe the sec. airvalve spring is adjusted too tightly. Does the kickdown function OK? Idle screws, perhaps the fuel passages are blocked with dirt or something, or there's a vacuum problem somewhere. The 'empty' carb priming is something more cars have and can be fixed by installing a simple fuelpump near the fueltank. Adding a thicker heat insulating spacer under the carb could help aswell.
If you decide you want another carb, I would personally go with an Edelbrock carb.
[Re: BigBlockMopar]
#739259
07/04/10 11:57 AM
07/04/10 11:57 AM
Posts: 30,430 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
Mega-DITTOS to SOME of what HermO said ..... 'cept that Eddy carb ... That is a stone-age carb compared to the TQ. You want FUEL ECON ? .... stick with the TQ. Get an older FACTORY service manual .... good info and tips in there. PLUS ....go to Napa and get a set of brass floats. Those plastic floats(using the alky-blended fuels) ...are NOT the plan.
[Re: BigBlockMopar]
#739260
07/04/10 01:12 PM
07/04/10 01:12 PM
Posts: 540 murfreesboro, TN
Qbird
murfreesboro, TN
All of his symptoms, with the exception of no secondary operation, can be traced directly to leaking wells in the bottom of the float bowl. Break out the JB weld an it'll be fine.
[Re: BigBlockMopar]
#739264
07/04/10 06:35 PM
07/04/10 06:35 PM
dartman366
Mt. Vernon, Ohio
Any one ever heard of Southern Carb's and rc hobby in Jackson Mississippi?,,,looked up Thermoquad's on E-Bay and they came up as a supplier,,,98% posative feedback. seem's to be reasonable on their pricing for complete rebuild's.
[Re: dartman366]
#739265
07/04/10 06:38 PM
07/04/10 06:38 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
How much do they want..........I did one years ago and heard it ended up on a bad ass record setting small block I`m just saying.... 1-760-241-1149
[Re: Thumperdart]
#739269
07/04/10 07:03 PM
07/04/10 07:03 PM
dartman366
Mt. Vernon, Ohio
239.00 for the one listed, and a 6 month warranty.I have your # wrote down in my little book of important people to know.
Is that a rebuild or exchange? I can definately beat that price..........And, I can get it back to ya in a couple of days. Oh, I`m not THAT important....
That is a buy now.
[Re: dartman366]
#739270
07/04/10 07:05 PM
07/04/10 07:05 PM
Thumperdart
State of confusion
That`s about right I guess.......why buy when yours was working and just needs a freshen and of course a few TWEEKS........your call......good luck.
[Re: moon]
#739272
08/02/10 09:58 PM
08/02/10 09:58 PM
dartman366
Mt. Vernon, Ohio
might ask this question in the resto section, I am sure those guy's would know, sorry I cant help but here's a for ya any way....oh and by the way the rebuilt thermoquad appears to work great, hope to take her on a short road trip this weekend.
